Really need Help
  • Fasteddie222
    • Feb 2015
    • 230
    Really need Help
    I've been searching everywhere for this and can't seem to find a solution. I am replacing the convertible latch handle and my problem is the short cable (drivers) is so tight that I cant even screw the handle in place. If I screw the handle in place and put the cable to the latch the cable is not long enough to reach. Am I doing something wrong? I know the passenger cable has the screw to tighten and loosen the cable but not the drivers side
  • loganhopeless
    • Mar 2015
    • 78
    Can you post a picture? I'm having a hard time picturing it.
    • Fasteddie222
      • Feb 2015
      • 230
      Yeah I'll get a pic in a bit. It's difficult to explain
      • Fasteddie222
        • Feb 2015
        • 230
        Really need Help
        • Fasteddie222
          • Feb 2015
          • 230
          Anyone?
          • flyboyx
            • 8371
            hmmm....i don't see enough information in those pics to see any issue. there really isn't any value in the first pic. the second: that silver ferule needs to slip inside the black barrel before you put the cable into the latch.
            otherwise, take a look at the routing of your cables. perhaps one is routed into the wrong position and is traveling a further distance than it needs to.
            Gigitty Gigitty!!!!
            • Fasteddie222
              • Feb 2015
              • 230
              The problem is the cable won't reach the latch.
              • Das Delfin
                • Sep 2014
                • 2293
                try slipping it into the latch first and then the handle after? Mine was tight too. There's a certain way it has to go in
                • Fasteddie222
                  • Feb 2015
                  • 230
                  Alright I'll try it out. Super strange. The car is in the shop getting a manual tranny and LSD :)
                  • McGyver
                    • 4614
                    There should be a tensioner somewhere. I replaced that handle a couple of months ago, but can't remember exactly how. Just trace out the cable path and look for a way to give yourself more slack.
                    • Semblance
                      • Jan 2011
                      • 433
                      Is it possible that the latch connection extends more when it is in the closed position? When I replace these I only disconnect the handle side and leave the latch side connected, so the latch would be closed. You can close the latch with a screwdriver to find out.
                      '89 lachssilber vert - Frau Blücher
                      '84 alpine 2dr - gone to the great beyond...
                      '00 titanium 4dr e46 - bricked
