a/c not cooling enough
    I have a 3 year old conversion to R134a, and even at full blast and with recirc on the cart remains hottish in 95 South Florida heat. Am I just expecting too much?
    My ir tool measured 40 degrees and I have about 25 psi on the low pressure line.
    Sorry that I can't help you, but coming from a guy who doesn't have working A/C, I'd be pretty darn happy with 40 degree vent air
    Sent from my XT1064 using Tapatalk
    (OO=[][]=OO) For Life
      40 degree vent temp at 95 C ambient is pretty good..
      55 degree temperature differential is on par with brand new AC systems.
        Mines ice cold. Isn't 25psi on the lower side?
          Lower is better.. But 25 is a bit low for a 95 degree day. If it's 25 at idle it's way too low. Pressure readings should be taken at 2000 rpm.
          Pressures are generally meaningless because they vary with ambient temp and engine rpm.
          Never fill by reading persssure. Filling by monitoring vent temp is the most effective way.
          Either you have a black car or non tinted windows.
          Just slowly fill refrigerant and see if vent Temps drop. If they don't there's no point in filling
            I have a white car but no tint.
              He's posting in the convertible section. That says a lot about comfort
              Alice the Time Capsule
                If the car is blowing 40 degrees in 95 degree heat, there is nothing that you can improve in the A/C system. The issue is air flow. If you were blowing air any colder than that, you’d just freeze the evaporator.
                Are you putting it on recirc? E30 A/C is immensely more effective run that way.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                  If it's running 40 degree air without recirc on it must be gods air conditioning
                    Speaking from experience, if you have a black convertible top in South Florida, your E30 a/c will have a really hard time keeping up, especially if the car is parked in the sun or you are running short errands and the car never gets a chance to really cool down.
                    I agree the 40 degree vent temps indicated a healthy system.
                    Sent from my iPad using Tapatalk
                    1992 325i Cabrio
                    1988 320i Touring
                    2000 M5
                    1977 530i
                    2015 328i - Euro Delivery/Performance Center Delivery
                    BMWCCA
                    E30CCA
                      I have same issue now that someone has made thread about it. I can only keep the car icely cold with ac if I am moving, I have the r134 conversion done but when sitting for a very long time it doesn't seem like it can keep up...
                      -R134 Conversion
                      -RedE30
                      -Black OEM Top
                      -Windows are not tinted
                      over all I am happy, better with it then without anything like rest of my e30's in past and present
                        -R134 Conversion
                        -RedE30
                        -Black OEM Top
                        Go to the aux electric fan in the front. Cut out the 6 Ohm low speed resistor attached to it. Solder and heat shrink on a new piece of wire of equal gauge to replace the resistor. Change what I remember as 15 amp fuse #3 with a 30 amp fuse. This makes the low speed side of the circuit the same as the factory high side of the circuit.
                        Benefit, the fan will now run at full speed greatly enhancing stand still and low speed A/C performance.
                        Downside, it's a little louder from the front due to fan noise. In the car, top down or up, you can't hear a difference.
                        Living in Texas, it's made all the difference.
                        Current - 1991 E30 325i Auto Vert, 2013 F30 335i M-sport, 2014 F25 X3 M-sport
                        Past - 1986 E30 325es, 1988 E30 M3, 1991 E34 535i 5sp, 1991 E31 850i 6sp, 1992 E36 325i, 1995 E36 M3, 2000 E46 323i, 2009 E60 535i, 2011 E90 335d
                          Jumping the resistor is a good idea, but rather than cut and solder just move the low speed wire to the high side lug. Not only is it reversible but the terminals are already there. Unscrew, rescrew, change fuse, be cool
                            Comfort Shmomfort
                            I drive with the top down so a/c isn't ends all be all, but it does rain here and sometime I am forced to put the top up. 90 and rain is awful in a car w/o a/c
                              I will try this. Ac was driving me about nuts in traffic.
