Looking for Suspension Suggestions
  • TKNH
    • Jan 2016
    • 10
    Hi,
    I have a 1992 e30 Convertible- 325i- with a suspension that I am looking to refresh. Car has 77K miles on it and its original. I am adding 15 inch euroweaves and am concerned about making the suspension too harsh or choppy for a convertible e30 so I am leaning toward a stock type setup. Anyone add a sway bar to theirs?
    Thanks in advance
  • Bearmw
    • 1323
    I would first consider:
    205/55/15 summer tires
    New bushings all around
    14.5 mm rear sway bar from an ix or M3
    E36 or E46 steering rack
    X brace
    After that I would consider:
    H&R sport or OE plus springs or similar
    Koni struts/shocks
    maybe slightly larger adjustable sway bars like 22/16
    * could also add fixed camber plates such as IE (1.25°) or Turner (.75°) ( both of these add about 11 mm stack height) or for more money Ground Control adjustable "touring" strut mounts (drops front about 20 mm)
    • allen_t
      • Feb 2014
      • 548
      Originally posted by TKNH
      Hi,
      Thanks in advance
      If you want the car lowered, you're probably gonna miss the comfy stock ride. I have HR sport / Bilstein sport set up / new bushings / with garagistic x brace and its a pretty comfy ride and not too low for my taste.
      Here is an old pic with the set up / euroweaves
      http://www.DeluxeCarStorage.com
      87 325ic - Early ACS Tribute
      90 325i MT2 - R.I.P
      Seller Feedback: http://www.r3vlimited.com/board/showthread.php?t=380908
      • cblais19
        • May 2017
        • 55
        This thread is relevant to my interests.
        I have an x-brace that was bought second hand without the hardware, does it normally come with longer bolts for the brackets/steering rack connections? Did you refresh the motor mounts at the same time?
        • Bearmw
          • 1323
          The X brace I got from Mason engineering had longer hardened bolts supplied with it. I don't know what is included with other brands.
          I didn't refresh my motor mounts at the same time because they were replaced at an earlier time and were still in good shape. I would replace them if they don't appear to be in good shape.
          • Arn02
            • Sep 2014
            • 8
            I just installed Eibach 318i Cabrio 30mm lowering springs and Bilstein B4's. I have had cars with tougher springs and B6's but since it's a vert I wanted it to keep good and comfortable handling settings. I may or may not uprate the sways with Eibach too. I really enjoy the way it drives and handles now. There really is no substitute for Bilstein gas dampers I think.
            Stuff:
            Result:
            • M-technik-3
              • 18946
              I like my 92 on Bilstein HD same valving as sports but an inch more of travel with E30 M3 springs. Gave it a not drastic drop and was comfortable for me. Add an X brace to add some rigidity.
              • cory58
                • 1021
                Looks good! Are the shocks bottoming out at all over bumps? I always thought that B4s could not be used with lowering springs.
                Thanks, Cory
                1992 325i Cabrio
                1988 320i Touring
                2000 M5
                1977 530i
                2015 328i - Euro Delivery/Performance Center Delivery
                BMWCCA
                E30CCA
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  Thanks, Cory
                  They can as long as the lowering is modest.
                  Alice the Time Capsule
