Very central locking
  • 968Reckless
    • May 2013
    • 1095
    Anyone know the difference in the wiring for the central locking of a vert compared to a coupe? I have 2 thick red/black wires going into the door plug and 1 coming out.
    I have 1 thin red/black in the relay and 1 thin red/black in the control unit.
    Trying to bypass the loop so I can start checking stuff of to get my locks working.
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
  • brutus
    • Dec 2016
    • 596
    sorry dont know ,,,,,, but wots common is the relay and some times the wire ends corrode in the door entry connection,,,
    best of luck,,
    I do have good relay avail if required, its in the side footwell ;)
    • 968Reckless
      • May 2013
      • 1095
      Fuse is good, relay has been swapped and no rust on the connections.
      I removed the loop according to the diagram but still nothing.
      Next step is replacing actuators.
      /// MTech Belts ///
      S52 BUILD
      M3 VERT BUILD
      • bradnic
        • Jul 2012
        • 3552
        No difference at all iirc. Download the e30 schematic PDFs to be sure
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • 968Reckless
          • May 2013
          • 1095
          So the wiring info I posted above it correct for coupes as well? Doesn’t seem that way from the pic below.
          /// MTech Belts ///
          S52 BUILD
          M3 VERT BUILD
          • 968Reckless
            • May 2013
            • 1095
            All actuators are good, control unit and relay are good.
            From the pic posted above I don’t have the jumper wire going from the relay to control unit this is why I asked if the verts had different wiring.
            /// MTech Belts ///
            S52 BUILD
            M3 VERT BUILD
            • jeffnhiscars
              • Jun 2011
              • 6010
              Did you check the thermal fuse inside the CU ? Its a low temp solder so its quite visible if bad and if you do decide to repair it do not use regular solder (AMHIK). I did that and blew every actuator in the car :-)
              Alice the Time Capsule
              • 968Reckless
                • May 2013
                • 1095
                Yeah my fuse was good. I actually got it working, ended up being the loop in the door. I thought I spliced the right wires but the door plug actually has 3 red/black wire but 1 is a gauge smaller compared to the other 2. Spliced the right wires and everything worked.
                Thanks for the help!
                /// MTech Belts ///
                S52 BUILD
                M3 VERT BUILD
