The Cabrio Suspension Thread
This is a sticky topic.
  • e304lyfe
    • 807
    #331
    Swapped my vert to h&r race and bilstein sports late last season. Sold on it being a suitable setup for a vert. It could be a bit stiffer in the rear. All OE but added the largest lower spring pad in rear.
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      #332
      Looks great! E90 drop hats would make it 100% perfect IMO.
      • e304lyfe
        • 807
        #333
        Thanks. .......I don't know about the car being much lower and being practical.
        • N2MYE30
          • Oct 2007
          • 5536
          #334
          I agree but I wouldnt kick it outta the garage for it. Do you have a 5-lug swap e304lyfe? Those are 16", right?
          COTM
          • CorvallisBMW
            • 13039
            #335
            After looking at that car, I'm suddenly a little sad I dropped $400 on GC coils to get the same stance as $250 H&R Race :(
            • e304lyfe
              • 807
              #336
              Yes, the car is 5 lug, and they are 16's.
              • CorvallisBMW
                • 13039
                #337
                M3 5-lug or e36?
                • e304lyfe
                  • 807
                  #338
                  M3 5-lug or e36?
                  e30 m3 suspension
                  • reelizmpro
                    • 9476
                    #339
                    Originally posted by e304lyfe
                    e30 m3 suspension
                    I see what you did there. E28 M5 or evo wheels? Genuine M Technic? I would run extra thick pads on top, in the back to bring it up some and give the springs more travel. Looks great by the way.
                    88 M3 - LACHSSILBER/SCHWARZE
                    • e304lyfe
                      • 807
                      #340
                      Thanks Barry! E28 M5 rims. Genuine m-technic 5-speed. I believe there is only one size upper rear spring pad available. I considered doubling them up though.
                      • N2MYE30
                        • Oct 2007
                        • 5536
                        #341
                        I was gonna do this exact thing on mine. Maybe 10mm instead of the stock 5mm.
                        COTM
                        • N2MYE30
                          • Oct 2007
                          • 5536
                          #342
                          pulled from realoem
                          15 SPRING PAD7,5MM 233531136386 $7.62 ONLY APPLIES TO COIL SPRING WHITE
                          15 SPRING PAD5MM 233531136385 $6.70 ONLY APPLIES TO COIL SPRING RED
                          15 SPRING PAD10MM 233531136387 $8.28
                          COTM
                          • e304lyfe
                            • 807
                            #343
                            pulled from realoem
                            Those are lower spring pads for an e30... sometimes used as uppers on other newer bmw's it appears, but their lower pads are different. Also, you appear to have a "2" in front of all the part numbers you listed that does not belong there.
                            • reelizmpro
                              • 9476
                              #344
                              What I did was took upper pads from my M3, cut the big nipple out of the middle and stacked it onto the existing upper pad already on the vert. This will keep that nipple from bottoming out too soon since it protrudes down quite a bit.
                              • e304lyfe
                                • 807
                                #345
                                Yeah, that is exactly what I was planning on doing... Either that or attempting to clearance the inner fenders more, but I think I may be about at the limit w/o causing a noticeable difference on the outside.
