The Cabrio Suspension Thread
This is a sticky topic.
  • Mr. Tasty
    • Jul 2011
    • 3421
    #511
    Originally posted by Jdesign
    Thanks. I was wondering because I am almost as low (about and inch higher) and my camber is only about -.5. I was wondering if the verts would be different for some reason.
    shouldn't be different, they use the same suspension components. There must be something wrong with your setup, as stock e30's come with like 1* camber in the rear
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • Wiglaf
      • Jan 2007
      • 1513
      #512
      the high camber annoys me.. gonna raise the rear a bit.
      Originally posted by u3b3rg33k
      If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
      • cory58
        • 1021
        #513
        So, I read all 35 pages of this thread, and am still not sure what to do. My vert has stock suspension. Original springs. Shocks replaced with Sachs OEM replacements about 10k miles ago.
        I just switched from 14" weaves to 15x7 BBS RZs, The rear height is fine, but the huge stock front gap looks even worse. What I'd like to do is just drop the front while keeping the Sachs shocks and OEM ride/handling. So what's the best solution? H&R Cabrio springs, coupe springs, M3 springs, hats, or something else?
        Thanks, Cory
        1992 325i Cabrio
        1988 320i Touring
        2000 M5
        1977 530i
        2015 328i - Euro Delivery/Performance Center Delivery
        BMWCCA
        E30CCA
        • jeffnhiscars
          • Jun 2011
          • 6011
          #514
          I've got a fresh set of h&r Cabrio springs with BS sports. It's "firm" to say the least. I think you will find stock dampers not suitable for the drop.
          Post 115 of my build thread to see how she sits
          Alice the Time Capsule
          • Mr. Tasty
            • Jul 2011
            • 3421
            #515
            [ATTACH]81826[/ATTACH]
            (Daily Driver)
            KW V2 Coilovers
            • F34R
              sLaughter
              • 12376
              #516
              My brothers '92 vert on GC coilovers, Koni SA valve matched and Condor speed shop M3 cabs.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • cory58
                • 1021
                #517
                Thanks Jeff. I'm thinking drop hats might be a good option, since the OEM shocks will probably have the same problem with any of the aftermarket lowering springs.
                Cory
                1992 325i Cabrio
                1988 320i Touring
                2000 M5
                1977 530i
                BMWCCA
                E30CCA
                • mpowerful
                  • Jul 2013
                  • 1273
                  #518
                  h & r coupe oe sport springs and e90 hats. :)
                  • ToPLeSS(e30)FeinD
                    • Jul 2011
                    • 2813
                    #519
                    i'll just leave this here
                    '89 Delphin 2.8 Cabrio
                    '94 Yamaha FZR 600
                    Originally posted by FlexdXJ
                    Is that thing on air?
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      #520
                      Originally posted by cory58
                      Thanks Jeff. I'm thinking drop hats might be a good option, since the OEM shocks will probably have the same problem with any of the aftermarket lowering springs. Cory
                      I think when we met I had already installed e90 drop hats after I replaced my blown OE struts with BS Touring. The drop barely made a dent in the stock cabrio reverse rake but for the $20 they cost it was a no brainer "while I was in there".
                      There may be a pic in my build thread before I did the full suspension swap if you want an idea and in the after pics the e90s are still in there.
                      • cory58
                        • 1021
                        #521
                        Jeff,
                        As always - thanks for the great advice. I'm running out of ideas that allow me to keep the Sachs shocks. Maybe OEM euro E30 springs + E90 drop hats would provide enough decrease in the front gap to be worth the effort. I wonder how hard it would be to source used euro springs?
                        Cory
                        1992 325i Cabrio
                        1988 320i Touring
                        2000 M5
                        1977 530i
                        BMWCCA
                        E30CCA
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          #522
                          Jeff,
                          Cory
                          I cant find my notes but when I spoke with Bilstein about how much lower I could go with the Tourings, they said there was quite a lot of range in them. As long as you are lowering only a modest amount they should be fine. Id shorten the bump stops either way.
                          • 01rs25
                            • Aug 2013
                            • 89
                            #523
                            Recently Finished suspension and car.
                            Bilstein Sports F&R
                            Ie3 springs
                            e90 Drophats
                            IE sway bar links
                            IE sway bushings
                            Powerflex M3 style LCA bushings
                            Condor RTABs
                            Condor Drop Subframe bushings
                            Wish it was a bit lower, but it will hold me over until i switch to air in the future.
                            • cavpilot
                              • Dec 2013
                              • 112
                              #524
                              What a great thread! I've read pretty much every word of it. I have a question: Has anyone tried keeping the stock springs and going with e90 drop hats in the front and removing the spring pads in the rear? I'm running Bilstein HDs all around with 14" weaves with 205/60r14, the rest is stock.
                              • TheTenor
                                • Feb 2014
                                • 70
                                #525
                                I need some input on what to run on my convertible. I've read through the entire thread probably 3 times now...
                                I'm going to be running 205/45/17s on E36 DS1 wheels with 42 Draft adapters. I want to get rid of this awful gap but not get super low. Wondering if I need to beef up the tires too...
