The Cabrio Suspension Thread
This is a sticky topic.
  • Poorhouse
    • Nov 2016
    • 497
    #616
    Just finished up refreshing the suspension on my 318iC.
    H&R Cabrio Sport Springs, E90 Drophats, Bilstien sports.
    1991 318iC
    1989 325i Field Rescue
    • DBShiznit
      • Feb 2017
      • 125
      #617
      These are all great but has anyone installed the megan racing coil overs? I'm wondering how they work on a convertible
      1992 325i Convertible - "project"
      1994 325is - Daily
      • Michael Star
        • Jun 2015
        • 265
        #618
        Im sure they would, I might worry about the rear springs pancaking due to extra weight.
        • Mixedbyjairo
          • Sep 2016
          • 103
          #619
          My mechanic told me if I put non vert springs on my vert that will lower it about a inch, is this true ???
          • phenryiv1
            • Jul 2009
            • 3246
            #620
            Originally posted by Mixedbyjairo
            My mechanic told me if I put non vert springs on my vert that will lower it about a inch, is this true?
            Only in the rear.
            Patrick Henry
            • Mixedbyjairo
              • Sep 2016
              • 103
              #621
              Originally posted by phenryiv1
              Only in the rear.
              I meant to say rear springs, so if true? Would I have to change struts also ?
              • phenryiv1
                • Jul 2009
                • 3246
                #622
                The struts will be the same as coupe/sedan models BUT if you are lowering the car and using coupe/sedan springs (thus lowering the car more than the convertible aftermarket springs would lower it) then you are further shortening the range of travel. For lowered E30s, Bilstein Sport or Koni Sport are the recommended option but you are going to lower it well into their travel range and thus risk bottoming out even the Sport struts.
                There are no shorter E30-designated struts but you may find another application (Camaro, maybe...I can't remember) that is shorter than the ones designed for E30s.
                Patrick Henry
                • Mixedbyjairo
                  • Sep 2016
                  • 103
                  #623
                  Thanks for the info, Ill have to think about what I'm doing, I have front BC racing coilovers, I have stock vert rear suspension, I just want to lower the rear about 3/4, but I can't find anywhere that just sale rear lower suspension..
                  • phenryiv1
                    • Jul 2009
                    • 3246
                    #624
                    You could use stock coupe/sedan springs to get .75-1" lowering. With the BCs being adjustable in the front you could dial it in to match the rear. Plus stock springs are cheap and take about 10 minutes to install.
                    Patrick Henry
                    • Mixedbyjairo
                      • Sep 2016
                      • 103
                      #625
                      That's was the plan but what you said before made rethink a little bit, but if I decided to go with coupe springs I should definitely use koni or bilstein. which is softer strut I don't want that rough of a ride
                      • fight4life28
                        • Apr 2014
                        • 821
                        #626
                        I have ie rear coilover adjuster and swift spring you could use for $100 shipped. You would have full setup then go out or down depending on the look and what model e30 you have.
                        • jeffnhiscars
                          • Jun 2011
                          • 6010
                          #627
                          If you use bilstein sports you will NOT have a soft ride..period. That's the singular compliant you hear about them and having just swapped them out on my cabrio for Koni SAs I'm not spekaing out of my ass (just this once).
                          I'm on H&R cabrio specific springs and the ride is as good as it gets IMO
                          Alice the Time Capsule
                          • Mixedbyjairo
                            • Sep 2016
                            • 103
                            #628
                            Any ever try Koni FSD?
                            • jeffnhiscars
                              • Jun 2011
                              • 6010
                              #629
                              I have fsd s on my A6 but they do not make them for e30s
                              • jjjcoutu
                                • Mar 2017
                                • 6
                                #630
                                The previous owner of my cabrio had them "professionally installed"; I'm in the process of raising in the ride height because the car was scraping on everything -- you could probably drop your car into the 7th circle of hell with these if you wanted. As per documentation on Megan's site, you'll want spacers if you have stock offset wheels otherwise the inner sidewall of the tire will rub against the top locking collars (NOT SAFE). I can try to answer any questions you might have though.
