And my sales brochure photo...
The Cabrio Suspension Thread
This is a sticky topic.
Posting up as my previous photos weren't on level ground.
H&R Race
Bilstein Sport
Full E30 M3 5lug
16x7.5" E28 M5 wheels, 225/45R16 tires
looks great!
Has anyone ever successfully used the green Racing Dynamics on Koni Yellow Sports?
Trying to dig up some more info around the RD's and H&R Sport rate differences. I've been running used vert RD's with new Koni Yellow Adjustable Sports (86 2277 Sport) for the past two years (which is only about 2k miles in total)
Recently, my front end is getting real bad and rough- I'm thinking with the heavy s52 and these RD's being god only how old and used- are finally losing their original spring rates. I'd prefer to upgrade to H&R's but really want to make sure that if I do switch over, that i'm not going any softer than what I have now. I have H&R Sports on my red coupe and they work great with Koni Yellow Adjustables (but as we all know, these verts are not as easy to dial into a good spring/shock combo)
These RD's are really hard to get any solid information on, curious if anyone has been through the same switch or vice versa and what they noticed in differences.
555Garage - Kingston, PA
'13 BMW e70 X5 35d
'95 BMW e34 525i
'92 BMW e30 325i S52 Vert (Quade the Vert)
'92 Range Rover Classic
'90 Range Rover Classic
'89 BMW e30 325i Coupe (The DIRTY30)
'81 VW MK1 Rabbit Caddy Diesel
'76 Honda CB550K Cafe/Brat
'67 Pontiac LeMans
'24 Model T Depot Hack
....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
This is H&R race with one coil cut off the fronts with 15" wheels and 205-50 tires
it's a Kenny Powers quote on wheelsComment
Thanks! It's got a cross brace in the front but no strut tower brace yet - I'm waiting for a local deal on one of those. I've noticed when cornering the chassis flex is now a bit ridiculous. I don't want to put a 6 point cage in my car so I may go back to H&R sports so the suspension is better balanced with the chassis flex
It's so bad that mid corner you have to readjust your turn in angle so the back of the car stays flat with the front, which is of course pretty distracting and quite scary. I set it up like this for autox but apparently stiff springs aren't always the answer!
1992 318ic
Split a 318ic with the girlfriend. $800-a-piece date car. I've been lurking for probably 6 months, and finally took the dive recently and bought absolutely everything I'll need to revamp my cars suspension. (Every bushing, shocks, springs, control arms, shock mounts)
I've never really worked on cars besides things like brakes and oil changes until I got this car, but I'm an experienced home motorcycle mechanic.
After reading through almost every page of this thread, I landed on something I don't think I've seen done yet. This is my parts list. Still waiting on the bilsteins and the drophats. I may end up getting cabrio springs, but I didnt want to go that low.
H&R OE sport springs (PN 50404-55)
Bilstein B8s
Rear: 10mm upper spring pad, standard lower
Front: standard spring pads, e90 drop hats
My thinking is that the OE sport springs will offer a modest drop (1.5) in the rear and not much drop at all up front. Hence the thicker rear spring pads in the back, and the drop hats up front. I'll play with it and try to get it right. I wish there were better options for the 318ic, as it seems everything is marketed towards the 325 cabrio.
What do y'all think? and thanks for reading my first post! I hope to be around for a while... when this m42 dies me and the girlfriend would love to do an s52 swap!Comment
1991 M-Tech 2
Bilstein B8 Sport front and rears with H&R Sport spring kit.
The front had a gap my fist could fit in before but now it’s just 3 fingers high, I would like to see the front a little lower but with a Garagistic X-Brace installed I was afraid that I would hit the ground one to many times if it was lower. I will be converting it to a 5 lug later on.Comment
