I pulled my fuel rail since I suspect that an injector is dribbling (losing fuel pressure over an hour, long hot start, fuel smell when starting car). I have heard it is safe to run the fuel pump to pressurize the rail to check for dribbling on the injectors. Whats a safe way to run the fuel pump manually? I have an early model M20B25 car with 2 fuel pumps and a return line.
EDIT: I already had my injectors cleaned and flow tested with new o-rings 4 years ago, from what I've heard injector dribbling just means the injector is junk. Is this true?
