DIY: Sunroof cassette/frame removal - with pictures!
  • eternal24k
    • Jul 2017
    • 507
    #31
    For those that did a delete years ago, how are they holding up? Does it look like a slick top after paint or has the patch become noticeable?
    • HCMW Adam
      • Oct 2016
      • 209
      #32
      I have a waterjet at work, so I just used that to cut the filler panel. It still needed a little sanding to fit. The welding process was easy enough. After finishing the panel I had to cut out a bunch of rust outside the sunroof hole. After finishing that bit there was a bit of waviness in the roof. I am not satisfied with it. There is also a little bit of rust outside that area on the other side.
      I plan to cut it all out, add some supports and do it again
      • MyE30
        • Sep 2013
        • 326
        #33
        That’s unfortunate. Did the waviness happen before or after the rust repair?
        • HCMW Adam
          • Oct 2016
          • 209
          #34
          I think it was pretty smooth before the rust repair. I spread the welds out and tried to manage the heat. The rust repair was all in on corner and I think I rushed that.
          • efficient
            • Feb 2012
            • 3312
            #35
            after removing the cassette does the roof flex more?
