Another E36-E30 Window Switch Question
  • Sean S.
    • Aug 2012
    • 196
    Ok, I know many of you have done this and it's probably considered a "done a long time ago", type of mod, but does anyone have the wiring diagram for the blue base e36 switches? Any links I find to the StrictlyETA write ups are long since 404'd and most other write ups are for the white base switches. I have 2 large blue base switches, 5 wires, with the following wire colors sw/gr, sw/ws, sw/gn, rt/vi, and sw/bl I'm putting these into an 88 convertible if that makes any difference. ANY help or pointers in the right direction is greatly apprciated!
  • 82eye
    • Jan 2009
    • 2011
    you should be able to get wire diagrams and colours from the etm for both models from here Index of /Manuals/BMW
    edit: this is in the same subforum you posted in DIY - E36 window switch retrofit - R3VLimited Forums
    it's for the blue base switches. ​
