Step 1: Remove the following fasteners and lift the front bulk head panel up and out. * Some 1987 E30s are equipped with fuel-cooling lines that run across the bulkhead and connect to the A/C lines. Neither the metal lines nor the rubber hoses need to be removed. Simply release the fuel-cooling lines from their
Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
