Front wheel bearing replacement.
Thats how the Bentley makes it sound.
Also I broke down and bought a 3 arm....
ส็็็็็็็็็็็็็็็็็็็็็็็็็Originally posted by blunttechI need you to exfoliate my ballsack
Great writeup! Anyone replacing thier hub mind selling me their good used inner race instead of just tossing it in the trash?Comment
Bump!!!
Just did this today!!!
Im rolling smooth once again. Thanks for the write up!
I wish the rear was this eazy
Transaction FeedbackComment
I'm sure theres a better way, but I lined up the hub with the spindle as well as I could, and rested the 36mm socket on the inner race, then tapped it in with a 2lb deadblow til it was past the threads, then drove it in with the axle nut and an impact wrench. Be careful, if you try to press it on by hand and aren't ready to drive it on, the rear inner race will stick to the spindle and the hub is heavy enough to pull itself off the rear race, which can and probably will damage the nylon bearing seats inside the bearing.*sigpicComment
So I need to buy the nut and the two dust covers as well? That's what pelican recommends.
Also what should expect to pay a shop to do this? I don't have a jack, jack stands, a garage and its my daily. Seattle, WAComment
anyone know if this 36mm socket will work? I cant tell if its thin wall enough.
http://www.amazon.com/TEKTON-4936-2-...ref=pd_cp_hi_0
I've used Tekton before and been happy. Its cheap. About half the price of the other amazon socket someone else recommended.98 M3/4/5
I always use a Craftsman thin walled socket. Fits right in there. If you don't want to keep it just return it when you're done, but its worth having a 32mm socket. Its a very common size for bigger nuts.
EDIT: Its cheaper too.
I bought mine from PepBoys for under $11. It looked just like the Tekton in the pic, impact gun 36mm, deep socket. Fit perfectly, but not much room to spare. Best of luck.
I've used Tekton before and been happy. Its cheap. About half the price of the other amazon socket someone else recommended.Comment
