Front wheel bearing replacement.
  • Simon S
    • Oct 2004
    • 3758
    #31
    Front bearings? Cake walk.
    Rear bearings? Fucking waffleswaffleswaffleswaffles whore son of a bitch sucking blood from the mother of all that is sacred on this rock hurtling through space.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • JUDGE
      • 8
      #32
      What can I expect to spend to do this per wheel?
      • djjerme
        • 5082
        #33
        If you get em through Advanced, it's only $60 per side for the bearing/hub assembly. Plus, they usually have some decent deals going..
        As for the inner race, several other Pro-3 guys gave me the tip of just slicing it up with a cut off wheel. If you happen to nick the spindle, it's not the end of the world, just hit it with some Emery cloth or sand paper (won't affect performance.) Considering these guys change their wheel bearings pretty regularly, they know some good tricks to get it done, quick like.
        2016 Ford Flex
        • cale
          • Oct 2005
          • 2331
          #34
          Luke I'm going to take appart one of the hubs I have pulled off and see what the bearing vendors at work can do for me. We deal with FAG and they make e30 hubs, so I'm sure there are bearings out there available for purchase so you'd just have to have them pressed in.
          As for autozone specials, buy decent stuff. Cheap bearings suck, and it's a pretty integral part of your vehicle which if it goes wrong is going to hurt.
          • Rigmaster
            • 3464
            #35
            Originally posted by 6erwebb
            Alright, I hope this isn't a dumb question, but I don't have a bearing puller . . is there anything else I can use or is that like the end all be all tool??
            Yeah, I know this question was posted several months ago, but you don't need a bearing/gear puller to do this job.
            To get the old hub off, once you remove the 36mm nut and the rotor set-screw (5mm allen) thread the lugbolts back into the hub, just enough so that they are securely in the hub (5-6 full turns should be enough). Now you can use the loose rotor as a sort of ghetto slide hammer- grasp the rotor at 9 + 3 o'clock and snatch it out away from the hub. You might have to do this several times if the hub is stuck on the spindle, but it will come off.
            If the inner race sticks like it seems to do more often than not, you can do what someone else suggested and carefully cut through it using a cutoff wheel or a sawzall, or you can try to carefully put the tip of a flat chisel between the edge of the race and the step on the spindle and tap it a bit, moving it to a new position eac time to slowly work the race off of the spindle.
            • Click
              • 637
              #36
              I believe my front bearings are starting to go. How long do front wheel bearings usually last?
              ส็็็็็็็็็็็็็็็็็็็็็็็็็
              I need you to exfoliate my ballsack
              Build Thread?
              • cholyoke
                • Feb 2006
                • 186
                #37
                I'm about to do this job as part of a larger project, but haven't taken the dust cap off. The bentley says to remove the 36 mm nut with the tire on the ground and a write up at pelican said to remove it with someone holding rotor/hub in place by depressing the brake. Is the 36 mm nut around a fixed spindle and you don't need to hold the hub still while removing the nut?
                • mcr_driver
                  • 4491
                  #38
                  When I did my front bearings I used a bar to hold the brake pedal while i used a breaker bar to remove to nut
                  • cholyoke
                    • Feb 2006
                    • 186
                    #39
                    Turns out that holding the hub or rotor still while removing the nut was unnecessary. Both came off with no problems. The hub just starts to spin a little once the bolt is loose, but the bolt itself came off with no problems. Impact wrench = Good times. Thank you for the write up!
                    • Fixcinater
                      • Apr 2011
                      • 110
                      #40
                      I just did this according to the workflow outlined here, which does a nice job of covering everything.
                      When I got to the 36mm nut, I stood on my 3/8ths drive Craftsman ratchet and snapped the internal pawls trying to break it loose. Had to put it all back together and get their (1/2 inch drive handle to get it done.
                      Also, my bearing fell apart as I yanked on the rotor to get it off...even the inner race basically slipped right off.
                      '89 325i
                      • b*saint
                        • 3794
                        #41
                        They actually aren't that bad.
                        Ma che cazzo state dicendo? :|
                        • Click
                          • 637
                          #42
                          Is the 3 arm puller absolutely necessary? I have a 2 arm that would fit.
                          Build Thread?
                          • io_RobbieRodgers
                            • Nov 2011
                            • 57
                            #43
                            You could McGuyver a super electromagnet, slap it on the hub bearing, chain it up to the back of a truck, and step on the gas of said truck. Like pulling teeth.
                            The next step is pray the bearing comes free before your strut is ripped out.
                            Reformed E34 addict. 1993 525i/5 - 1995 525i/5 - 1991 318i/C
                            • 36brua
                              • 689
                              #44
                              try this.. easy GL
                              Find information, resources and relevant links for e30world.com. This domain may be for sale.
                              My CA legal M60 swap
                              The happening in our garage
                              • TurboJake
                                • 3780
                                #45
                                Sometimes they pop right off. Especially when below 30 degrees.
                                But there was one inner race I had that stuck. I slotted it with a dremel, and cracked it with a 3lb maul and chisel. No heating the spindle. No puller possibly chewing stuff up. No damage to anything except my face. Which is pretty fucked up already so it's all good.
                                Leave Me Transaction Feedback
