DIY - E36 window switch retrofit
  • JDMpower
    • Sep 2006
    • 1771
    #136
    Oh well - I am only out 10 bucks for the set! :) I will try to find the blue or white ones. :(
    '89 "is" = M technic II build mode.
    • JDMpower
      • Sep 2006
      • 1771
      #137
      I got some blue ones now - there is no harness with them, so does anyone know the pin layout for them? I will then just make some push on connectors.
      Thank you!
      Josh
      • wycoco
        • Feb 2006
        • 723
        #138
        Aww, pictures dont work! Fix them Josh, please?
        • JPL
          • May 2005
          • 774
          #139
          go to http://content.hooddumpe30.com/ and in the write-ups section there is the e36 window switch retrofitting with the pictures.
          Originally posted by Hawt drift chick
          Yeah, i'm a good dude i swear, i just like to be balls to the wall.
          • JDMpower
            • Sep 2006
            • 1771
            #140
            Thank you!
            Josh
            ANYONE?????????????
            Do the #'s mean pins?
            E36 Blue Base:
            Negitive (-) 1 - Black/Yellow
            Window Down 3 - Blue
            Window Up 4 - Black
            Positive (+) 5 - Green/Grey
            Negitive (-) 6 - Blue/Green
            • JDMpower
              • Sep 2006
              • 1771
              #141
              also - anyone do a blue base and light ended up working?
              • JDMpower
                • Sep 2006
                • 1771
                #142
                Done - light comes on - all buttons work. I used stock e30 wires to e36 blue base pins. (switch without the e36 harness part)
                • JPL
                  • May 2005
                  • 774
                  #143
                  man i just finished mine after four #17 blown fuses because i couldn't resist touching wires together with my key turned to two clicks
                  • mike85-325e
                    • Dec 2006
                    • 13
                    #144
                    has anyone installed one of the large white base switches in the rear? ive tried to follow BDsax's wiring but i either blow a fuse or the e36 switch doesnt work and the switch in the console works backwards. ive tried switching around the wires but nothing. and never has the e36 switch work. i also used two different switches just incase it was a dud. any advice?
                    • delatlanta1281
                      Dart Master
                      • Mar 2006
                      • 10317
                      #145
                      Is it a one touch?
                      I think I have white bases in my front....
                      Did you fry the switch?
                      Yours truly,
                      Rich
                      you kids get off my lawn.....
                      • mike85-325e
                        • Dec 2006
                        • 13
                        #146
                        i dont know. i poped a fuse though. its not a one touch. its a four wire large white base switch. i tried two switches. how can i test to see if the switch is fried?
                        • franco90
                          • 3185
                          #147
                          I ordered 5 blue switches and 5 flush things so I let you know how they worked
                          5 switches x 17.00
                          5 flush thing x 2.00
                          I've always been proud of being a Marine.
                          I won't hesitate to defend the Corps
                          "Supersquad"
                          ‎"Prostitutes are a sub-category of Amusement Parks"-
                          • franco90
                            • 3185
                            #148
                            can you post a picture or explain to me how to do it.
                            I just order my blue buttons from BMA. thanks Franco
                            "Supersquad"
                            • p-lo
                              • Feb 2007
                              • 50
                              #149
                              I don't know if this was covered, but does anyone know if the dealership carries the wiring harness for the BLUE BASED Switches (PN BLUE: 61 31 1 393 361) as indicated in the DIY??
                              • franco90
                                • 3185
                                #150
                                Originally posted by p-lo
                                I don't know if this was covered, but does anyone know if the dealership carries the wiring harness for the BLUE BASED Switches (PN BLUE: 61 31 1 393 361) as indecated in the DIY??
                                I am wondering the same because my switches be no good with out harness
                                "Supersquad"
