how to(with pictures): de-power, disassemble, ects.. 318is steering rack
  • mr.vang
    • 4371
    i post a DIY on m42club and just want to share with r3v.
    I have a 318is steering rack laying around so i decided to open it up and give it some lube.
    TOOLS:
    impact gun(unless you want someone to hold it)
    19mm
    17mm
    12mm
    13mm
    7/8 socket
    long, bent nose pliers
    auto grease
    flat head screw driver(for the seal)
    lets begin shall we:
    lucky my rack was already out because i replace it with a m3 rack. The rack was kind of dirty so i give it a wash with one of my mom kitchen cleaning.
    remove these line from the steering rack using 12mm(your going to need it later)
    I let the rack dry and went to eat breakfast, played some CODmw2, and went on m42club. ok first thing remove the cap(as seen in the picture)
    sec. use a bent or long nose pliers and grab the locking ring( there should be two holes on the ring for you to grab it)
    next step: use either 19mm or 17mm(i forgot) socket and impact gun.
    now you should see some balls bearing inside( don't worry they won't fall out)
    it should come out like this
    remove the o-ring(replace it if you are going to power your rack)
    next step: remove two 13mm bolts
    there should be a spring and a washer inside
    next step: on the other side, there is a locking ring inside. you can see it through the hole. push it up through the hole and grab it with the pliers. (i already got it taken out in the pictures)
    hooray!! the steering shaft is out
    as you can see my o-ring seal was no good(also hard)
    remove it
    now: everything should be out of the shell by now. clean the inside as good as you can ( mine was as clean inside)
    grease time( look how hard and dirty the old grease was. p.s. look like shit too)
    you can replace all these seal. i didn't because i'm not planning to power this rack
    don't forget to lube the ball bearing
    now put everything back where it belong(finish product)
    P.S. I enjoy some homemade peanuts along the way :)
  • mr.vang
    • 4371
    enjoy
    • Dj Buttchug
      • Jun 2010
      • 7678
      damn nice write up. I really need to do this to mine
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • AbsorbantNut
        Non faccio funzionare questa merda
        • Jun 2010
        • 2491
        great write up, makes me want to do this to mine.
        '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
        • tonywonder
          • Sep 2009
          • 1688
          sweet looking into doing this soon. for now. pump belt is just off. are there any holes that need to be plugged on the rack?
          • mr.vang
            • 4371
            yes all of them to prevent debris from going in
            • ///digitalme
              • Dec 2009
              • 2088
              so if you replace all the o-rings, and washers..and all that...would that be considered rebuilt??
              i need to do this on my spare rack
              • mr.vang
                • 4371
                yup, just get a rebuild kit and your go to good. its easier than i though.
                • ///digitalme
                  • Dec 2009
                  • 2088
                  umm
                  thanks for the diy ill for sure be doing this!
                  • acolella76
                    • 2950
                    so i'm guessing the process is the similar for an E36 rack? Good, hopefully i can save a few dollars buy rebuilding a rack i found at the junkyard instead of buying a brand new kit
                    -Alex
                    • acolella76
                      • 2950
                      I can not find a single place that sells o-rings and seals for the racks. Anyone know where to find them?
                      -Alex
                      • IsoGrifo
                        • 82
                        take the old ones with you, go to ACE Hardware, or a true value, they usually have the best selection of O-rings.
                        • acolella76
                          • 2950
                          can anyone confirm that this will work on an M3 rack? http://www.partsgeek.com/gbproducts/...ek+Google+Base
                          -Alex
                          • Coyote
                            • 30
                            I ordered the specific seal kit from World Pac for $54 w/ tax
                            93 MR2 Turbo Dedicated Racecar (R.I.P. )
                            04 350Z Nismo S-Tune (sold)
                            91 318is Coupe (stored away)
                            03 330i ZHP Sedan (sold)
                            04 M3 Coupe street / track (current)
                            03 Legacy Outback (daily beater)
                            • M42Power
                              • Dec 2009
                              • 519
                              How does unpowered power steerin racks feel? Do they feel like my euro manual steering or heavier?
                              Originally posted by kendogg
                              Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
                              OG RACECAR
