DIY: Replace ball joints on your stock control arms (10ton or greater press required)
  • bmwguy325is
    • May 2011
    • 1263
    Originally posted by Voluted
    It takes quite a bit more time (an hour or two depending on experience) and isn't worth paying some one to do for you. With the price and availability of Meyle HD arms now, I wouldn't bother doing this unless you have the free time and the right equipment.
    I do the work myself but I can change the entire arm quicker than that. So to me its "cheaper" to buy a rebuilt arm.
    ..... Now have you tried changing the joints on Aluminum M3 control arms?...
    Now this would make it worth someones time.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • Northern
      I like cupcakes & sh!tboxes
      • 5283
      Originally posted by Boostesi
      You can do this without the hydraulic press if you have the c-clamp style ball joint press kit.
      My experience with these kits is that either the threaded rod bends or the "C" part bends before it actually pushes the ball joint out. I think its worth it to use a real press. I also feel like it would be a lot of fun to try to use this on the inner ball joint because of the long stud it has.
      Also, there is an arrow on the bottom of the ball joint for alignment purposes. I don't remember which way it is supposed to face though
      Originally posted by priapism
      Originally posted by shameson
      • irish44j
        • 2763
        I couldn't imagine trying to do it with the C-clamp press. When I did mine I'd say my 12-ton press BARELY was able to pop it out. I was standing around a corner while pumping, the whole assembly was so loaded up.
        But they finally popped out. Putting in the new ones was much easier :)
        Moog FTW
        Stage rally/rallycross e30 build/competition journal
        Track/street e21 build
        visit Condor Speed Shop
        visit Motorsport Hardware
        [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
        • ///M42 sport
          • 3952
          wow glad I found this thread. I think Ill be doing this in the near future...it seems like a waste to throwout OE control arms.
          • brent5631
            • Jun 2012
            • 421
            Even the balljoints that autozone carry are actually manufactured by moog. so its pretty cheap and easy to get through them. I changed my joints with the proper size press sleeves and a 2 lb mini sledge. Just have a buddy hold it and whack the crap outta it. Worked fine and took 30~45 min to swap the joints.
            • IveGotIssues666
              • Oct 2006
              • 517
              That's because they are cheap made in china c clamps (Harbor freight brands etc...) heck even the OTC ball joint press over time ended up stripping out however the c-clamp didn't bend
              I've had no issues with my current ball joint press which is a snap On BJP1 http://buy1.snapon.com/catalog/item....store&tool=all the thing is a beast and even if any of the adapters or threaded rod/clamp were to strip/bend they are warrantied which is surprising considering its a wear and tear item OTC wouldn't do that.
              Heck I now its expensive and not worth it for a DIYER but its a nice tool that would pay for itself I usually see them pop up on craigslist and ebay for around $450 in good used condition
              • lowsodium
                • Dec 2012
                • 289
                You can rent these kits from advanced auto for free.
                The 12 ton press from Harbor Freight is like $104 with a coupon. Easily resold too.
                Haven't you ever seen Russian Nesting Dolls? They work like that.
                1987 325e / 2008 135i
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  I wouldn't do this with standard caster CAs since they are so cheap, but it's a good idea to replace the joints on used lemfoerder 96+ e36 m3 CA's. Those cannot be had in new condition for cheap.
                  • nickmcc92
                    • Dec 2012
                    • 442
                    I rented a ball joint press like this from pepboys.
                    All I needed was a breaker bar and socket to push out the ball joint.
                    Requires a lot of thinking knowing where to put socket and the cups.
                    But you can do it yourself without a shop press.
                    • cdubvw
                      • Feb 2013
                      • 18
                      Just did all four of my ball joints this weekend with a 20 ton press, took maybe 15 min to press the old ones out and the new ones in. Very easy!
                      • DIIRTY-30
                        • 1665
                        Easier to replace the whole control arm along with the CAB's while your at it honestly... Unless you have access to a dope ass friend with a press. In which case, more power to you.
                        BLUE NOSE - M62 SWAP
                        THE E30 + 1 BUILD
                        • IveGotIssues666
                          • Oct 2006
                          • 517
                          Yeah one of those cheap OEM Brand Kits... guess what the clamp bends (Can you say Made in China) just like the cheap Harbor Freight ones I would stay clear (Not the Hydraulic Press but the Ball Joint Press Kits they have)
                          • jrobie79
                            • Mar 2006
                            • 2526
                            what'd you guys all use for replacement ball joints?
                            1991 318i ---- 308K - retired
                            • 10Toes
                              Me Father Was A Tree
                              • Jan 2008
                              • 61222
                              Amazon Prime has Lemforder
                              • AbsorbantNut
                                Non faccio funzionare questa merda
                                • Jun 2010
                                • 2491
                                Moog
                                '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
