DIY Put a Rear bumper strip on the front
    I just cut a piece out of the middle of the rubber trim and kept my turn signals. Used the same methods with the washers, just put 1 in the middle
    With smoked turn signals
    Cammed B25 Swap Daily Driver
    Updated 10/1
      Originally posted by straight6pwr View Post
      the only immediate issue with this solution is once you seal the headlight back up, replacing a dead LED would be near impossible. (i had one dead after a few months)
      Instead of putting it in the headlight what if you put it behind the grill next to it?
      I took you pic and did a quick ms paint mock LOL
      SO MUCH MORE TO DO!!
      IG: ohthejosh
      LEGIT CHECK ME BRUH
      BUYER FEEDBACK THREAD
        Ive thought of this same idea, but im in fear the midification is to "new" for the car. it seems way ahead of its time. Plus there is a retaining screw in the middle on the bottom slot to hold the grill on. You would either not use the bottom slot, or have a weird gap in between :D
        I would rather replace the whole trim cause putting a piece from an other car may be noticable. The wear patters may look different, thus revieling the replaced piece, unless you get lucky.
        I don't even own this car anymore, but I'm too lazy to change the picture.
          Seems like the stock filler piece is likely to cost less than fabricating new turn signals.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
            thought about that idea of the corner area of the grill, but keeping road grime/dirt/rain from the electric components would be very difficult.
              Ive been wanting to tinker with little projects like that just for fun. I think I will try and make a nice set to see how it looks with proper housing and all.
              IG: ohthejosh
              LEGIT CHECK ME BRUH
                This is true in my because only because I used plastidip... Which when applied to rubber gets hot a sticky. A little bit of driving and I have rocks stuck only in the rubber section lol
                Did it mostly so I could put the plate on easily though. Maybe working against me though :???:
                Updated 10/1
