Rear air bag install, Front air bag strut build on a e30.
    Hey. Just wondering wat items u ordered for if someone wanted to do a similar setup on there car from the website link u post at the begging of ur write up. Thank u
      x2 on that^
      however i believe the front struts are airlift item 75564
      not sure what rears he is using but 50252 looks really similar.
      also, i think they come with elbows for 1/2 inch lines? so you gotta get elbows for whatever size line you are using.
      www.cp-e.com
      1989 Zinno 325i m52 turbo coupe
      2015 Ford Fiesta ST, Daily Driver.
        correction i think the rear bags are air house 2
        www.cp-e.com
          Question are you still running a front swaybar? Any modifications to the links?
            Originally posted by mitchlevy7 View Post
            x2 on that^
            Actually, if you use the 75564 it's too long.
            The rear bags are UAS AH2's in the 3/8" port size.
            I'm the guy who sold Mike all his stuff ;)
            OPEN ROAD TUNING
            the original e30 air suspension provider
            P: 610.572.2898 // E: andrew@openroadtuning.com // Facebook // G+
              So which is the correct part number for us to use on e30's?
              Rali at bagriders suggested this strut.
              Thoughts guys?
                Go with the rolling sleeve. I've found that its a better ride. Also a skinner bag which leaves plenty of room for wheel fitment. The double bellow like you posted is to wide. E30s don't have that much room to play with.
                  Ive pmed you about this question before. Do you have a part number or a link to the rolling sleeve one?
                    I believe #75564 is the best way to go.. correct me if im wrong
                    MY BUILD THREAD
                    http://www.r3vlimited.com/board/showthread.php?t=235231
                    INSTAGRAM : @luchcolaneri
                      And I have answered you every time. It is 75563
                        I have the e36 5 lug set up on a e30... is this the same thing? Please help lol.
                          Thoughts guys?
                          The double bellow will not fit in the E30, we've taken measurements and we've found the 75563 to work the best :)
                          OPEN ROAD TUNING
                            75564 is shorter then 75563..... but has less stroke. 75564 works.
                            www.cp-e.com
                              What are you guys doing about the front swaybar? Running shorter links?
                                How will the double bellow not fit? When the double bellow is aired out, it decompresses itself into a sandwich making it smaller than a rolling sleeve. When a rolling sleeve collapses, it takes a lot of expansion which may cause the bag to rub against the wheel when decompressing.
                                MY BUILD THREAD
