So what all is needed to run e36 bag kit on an e30?
Rear air bag install, Front air bag strut build on a e30.
Static 4 lyfe1989 325i SETA stroker [delphin] R3V'd 8/31/2011
1989 325ix [zinnoberrot] $OLD
1970 2002 [Nevada]
Originally posted by Herr Faust Schinkenguy must have slid into something that doesn't look like a car vs car hitOriginally posted by ak-Must of slid into RobComment
Go away Rob lolBronzit 4-door Swap Drifting somewhere
Cammed B25 Swap Daily Driver
Updated 10/1
Originally posted by StereoInstaller1Maybe 300 CANADIAN HP, thats like 225 US HP.Comment
So correct me if i am wrong guys
Front Bags
Air Lift Performance - Universal sleeve over-strut kit (75563)
Rear Bags
Bag Riders - Air House 2
http://bagriders.com/modlab/products/AIR-HOUSE-2.html
And a management kit of your liking, preferably V2 because Digital is an easier install.
I will be ordering the above parts soon so I just want to make sure in order to get the right parts.Comment
Make sure you hit up Andrew at ORT and mention my vert or Mike Hockman for the best deal around. :)So correct me if i am wrong guys
Front Bags
Rear Bags
Best deal and I do e30 installs. I also work with Andrew for front kits already welded and ready to go. Shoot me a pmComment
You cut the supplied tube to the length that you want. If you don't want slammed. You can go with a bag over strut setup.Comment
Mike, how do you tuck so much tire in the front? Are you 24v swapComment
On my coupe yes. My vert no. And it all comes down to the little things. The nubs on the control arms I cut down to clear. Above the front tire I cut the pinch weld off and weld it shut. Shim the engine up if need be. Every car I bag. Lays front subframe.Comment
You sir are a god, ill pm you for pricing on full kit for my sedan1991 325i Schwarz coupe AT
Check out my wtb thread changes often | SoCal |
http://www.r3vlimited.com/board/showthread.php?t=293850
Feed back thread, if you deal with me leave a comment!
http://www.r3vlimited.com/board/show...63#post3847663Comment
