Rear air bag install, Front air bag strut build on a e30.
  • rasjgo1
    • Aug 2011
    • 332
    #106
    I pm'ed u ro
    Sent from my SGH-T999L using Tapatalk
    • ForcedFirebird
      • Feb 2007
      • 8300
      #107
      Thanks for the tips Mike!
      john@m20guru.com
      Links:
      • Vanilla Gorilla
        • Dec 2006
        • 357
        #108
        Clearly needs more low :D:D
        • Boris0bmx
          • Feb 2014
          • 28
          #109
          Is that at its lowest in the rear ? I dont like the idea of cutting of those "nipples"...cant it go that low without cutting?
          Great build !
          Brussels Finest - E30 Coupe
          • White325is
            • Oct 2006
            • 5947
            #110
            That is the lowest in the rear you can go . I can price bolt in setup from airlift for you. No cutting necessary.
            • z28
              • Oct 2014
              • 362
              #111
              Through where are you guys routing the air lines for the front bags?
              First e30 - 1991 318i 4 door
              • White325is
                • Oct 2006
                • 5947
                #112
                Through the car or Under the car it is up to you.
                I usually following the fuel/brake lines up front and run the passenger one across the subframe.
                • Robs0nic
                  • May 2015
                  • 28
                  #113
                  So, I've recently bagged my bronzit E30. I've had an issue where it's not quite sitting all the way down in the front. Pic for reference, anyone else had this issue at all?
                  *Edit, after reading through this thread a bit, finding that just making small trims in the front should help quite a bit.
                  Uh duh.
                  • 280zx2by2
                    • Jan 2017
                    • 2
                    #114
                    Sorry for the dead thread bump but as far as camber plates does anyone have an
                    inclination of if these COSMO plates for "COILOVER AFTER MARKET MOUNTS" would
                    work with the Air Lift 75563 strut?
                    COSMO for aftermarket
                    COSMO for factory strut
                    • White325is
                      • Oct 2006
                      • 5947
                      #115
                      http://www.cosmoracing.com/productin...d=301&pid=2085
                      you need the airlift specific plates for the struts unless you make adapters to fit aftermarket.
                      • 280zx2by2
                        • Jan 2017
                        • 2
                        #116
                        After getting the front struts in and taking a few measurements and from messaging Cosmo it looks like you'd need to machine the shoulder of the strut down .650" and die the threads .650" further. Also have to make a .866 length bushing with 14mm OD and 12mm ID (.039 wall) to account for the difference in the camber plate pillow ball and strut shaft.
                        Would the strut be fine running on the just camber plate like that or would some sort of thrust bearing need to be added? I can't remember how the coilovers on my old S-chassis used to account for rotation. I'll see if can get pictures tomorrow.
                        I may just go ahead and machine the struts, then if I decide to go back and install camber plates it will be a lot easier than trying to fit them on the mill with the spindle welded on.
                        • Buzz944
                          • Apr 2017
                          • 21
                          #117
                          Sorry to revive this old thread but I really really need those pic and they are not opening
                          Anyone by chance have them or can send them to me?
