A/C Switch not working? Fix it for free
  • bowtie2bimmer
    • 830
    Has your a/c switch not been working properly? Have you had to fiddle with it to get it to stay on? Does it cut out while driving?
    All these were happening to me and i figured I would try and fix it before buying a new switch. This is really simple and I'm sure most of you already know how to do this (there may even be another write up, I didn't look)
    Here is the culprit:
    To get to the inside, all you have to do is take a small flat head screwdriver and pop the out cover around the tabs on the side
    When you take it apart you'll see the two bulbs, springs and a little grey plastic tab between them. The little tab fell out as I was pulling it apart so make sure you don't lose it.
    You can tell by looking at the connections inside and out that there is a far bit of corrosion. Its 25 years old so that's to be expected.
    Take the springs off and push the lights through the bottom, this will give you more room to get in there to clean the leads. I used my handy dandy dremel for the job
    After about 5 minutes of scrubbing away, you can clearly see the difference
    Put the switych back together and reinstall everything. Now it should work with ease. Before i had to like press it several times to get good contact, not now, works flawlessly with one push
    Hope this helps some of the broke e30 owners. You can do this to any of the switches they you are having problems with.
    1987 BMW 325ic - Emma
  • Poorboyz
    • May 2012
    • 2117
    I was actually going to do this today when I came across this thread. Thanks for the write up.
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • DisgustipatedAP1
      • Mar 2012
      • 421
      Does this work on the air recirculation button too? I think the springs on mine broke cause it won't stay pushed in.
      RIP: Delphin '89 E30 with S50 swap and lots of goodies :'(
      Then: '04 Evo 8 RS, 500 whp/420 wtq 2900 lb E85 AWD turbo shits 'n giggles
      Now: 2003 BMW M5 in Sterling Gray
      • yanal
        • Jun 2011
        • 248
        Nice write up !
        Sticky:True e36 one touch windows DIY
        1990 M3
        1992 Mtech (S50 + 5 Lug)
        • e30Villain
          • Jun 2012
          • 540
          Useful thread.
          If only fixing my AC was this easy.
          87 ETA | Hibernating
          • bowtie2bimmer
            • 830
            Ya, same switch housing so you kinds do both anyway.
            • Mendi3
              • 110
              Thanks for sharing.
              OO=(ll)=OO
              91 E30 Coupe 325is 5 Speed
              • astiv43
                • 21
                If your button won't stay pushed in, then your fix probably won't be this easy. There is a tiny white plastic tab that breaks off, and gets lost. So unless you are a glue ninja, you're looking at a replacement switch.
                astiv43
                '89 Zinoberrot 325i 'vert, auto
                • astiv43
                  • 21
                  Check out the pictures here:
                  astiv43
                  • M3 euro ltw
                    Site Sponsor
                    • 259
                    Sweeeet
                    You certainly don't need a new camera either, nice photos.
                    You do need a steady hand, some micro-fine brushes and some white paint to tidy up the markings now!
                    Trying to make the world a better place, 6 TB at a time.
                    http://abloriginalparts.com/
                    • DisgustipatedAP1
                      • Mar 2012
                      • 421
                      Pick-a-part time!!:D
                      • Poorboyz
                        • May 2012
                        • 2117
                        I have a spare switch with perfect white icons that I'm cleaning and selling. Looking for a defrost switch with perfect white icon and a headlight switch knob with perfect white icon if anyone has one they want to sell or trade.
                        • Just Scott
                          • Dec 2010
                          • 140
                          If you don't have a dremel handy, try CRC electrical contact cleaner. Works well for these kinds of repairs.
                          1990 325is - sterling silver, very nice, maybe for sale
                          • mike.bmw
                            • Dec 2015
                            • 1762
                            Bumping an old thread. My AC button doesn't stay pushed on. The AC works, but I have to press the button many times for it to stick.
                            Only one of the photos in the original post works. :(
                            • bowtie2bimmer
                              • 830
                              Try now. I fixed the photo links
                              Sent from my SM-G920V using Tapatalk
