Common E30 Spring rates
  • Joe318is
    • Sep 2005
    • 6451
    Is there anything out there that lists the spring rates of ALL springs made for e30's? For example, GC are listed and sold by their spring rates, however many 'sport' or 'touring' springs are not sold the same way.
    Where i am going with this... i have a set of H&R Sports from an 84 318i on my 318is.,.. just curious of the spring rates in comparison with GC's.
    Originally posted by vlad
  • 2002maniac
    • 4260
    Here is a list I compiled which required alot of research. It should be stickied.
    All numbers in Lbs/in Front -> Rear
    E30 spring rates
    Stock M3 -> 140 -> 250 (others say 100,300?)
    Dinan Sport -> 172 -> 300
    H&R Race -> 315 -> 570
    H&R Sport -> 185 -> 380
    Eibach Pro-kit -> 102 -> 277
    Eibach Race -> 160 -> 445
    Ireland Stage 3 -> 315 -> 570
    • Joe318is
      • Sep 2005
      • 6451
      sweet! thanks!
      • DarkWing6
        • Apr 2004
        • 7144
        This thread should be moved to FAQ
        Great info 2002maniac.
        • silversleeper
          • Mar 2005
          • 2032
          question bout the H&Rs... are the race springs red? My H&Rs are a metallic gray if I remember correctly, I duno what level they are though.
          Claus Luthe is my hero.
          • asubimmer
            • 6482
            anyone know for bav auto springs? I have em but don't know the rates.
            • 88325isboy
              • Mar 2004
              • 1058
              Ya does any one know what the rate is?
              '87 325 (Track Rat)
              '04 C5500 Wrecker (Work)
              '94 525i (Daily)
              '90 325i (R.I.P)
              H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
              • 2002maniac
                • 4260
                Look at the part number on the springs and reference it with H&R. There have been different colored springs depending on batch IIRC.
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  my HR race are red.....
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    What is the rate of Tokico's???
                    Originally posted by 325Projectz
                    don't listen to the diagram... listen to mr. swiss.
                    :nice:
                    • trashcop 80s 80s
                      • Jun 2004
                      • 1130
                      Not many people go this route but I love them.
                      OBX coilover for e36 fitted onto e30
                      305 lb front
                      450 lb rear
                      • Jordan
                        • 12913
                        305 lb front
                        450 lb rear
                        No one goes that route because its garbage.
                        https://mtechniqueabs.com/
                        • trashcop 80s 80s
                          • Jun 2004
                          • 1130
                          I don't see why everyone thinks that. Maybe its because some people on Max installed them halfass and used stock shocks with them that bottomed and bounced to shit which gave them a bad rep.
                          The threaded sleeves and collars are very acceptable quality, I don't see how there could ever be a problem with them. I have never seen gc before but I would say that the OBX sleeves and collars are the same quality. There is not much that could go wrong with such a simple part. I have had them in for about two years without any problems. If you have ever seen, rode in, or had actual contact with them then you might know what you are talking about.
                          As far as the springs go, they might not be tested, who knows. There was talk about them having like 250/325 rates or something, I don't know where those numbers came from but my fronts clearly have 53 hg stamped on them, which translates to about 302.7 or something, and the backs have 450 marked on them. I don't know where OBX sourced them from but from two years of having an e30 sit on them they haven't sagged. I could put new ID springs if I ever have a problem, they are available from many different places and I would still come out cheaper than gc.
                          • Jordan
                            • 12913
                            I've heard so many horror stories of the OBX adjuster collars just snapping, or the sleeves stripping out.
                            They are made of cheapo aluminum, and thats that.
                            I have seen pictures of the OBX shit compared to the GC goods. There is no comparison between the 2 other then the intended purpose.
                            • george graves
                              • 19996
                              what about a list of the approxmiate drop?
                              Originally posted by Matt-B
