Common E30 Spring rates
  • luTTz
    • May 2007
    • 204
    #31
    I'm running eibach 2.5" diameters springs rated at 550# for the front and 650# for the rears.
    just saying, those rates are out there too. by switching to 2.5" springs, i have an almost infinite selection of spring rates.
    • Bill-B
      • Apr 2007
      • 1242
      #32
      Originally posted by kingmanjr00
      Spring---------------------Front(lb/in.)-------------Rear(lb/in.)
      Stock 325i-----------------------106------------------------245
      Stock 325is----------------------118------------------------265
      Stock 325ix----------------------106------------------------308
      Stock M3-------------------------114------------------------314
      Stock M3--------------------------140------------------------250
      Dinan Sport-----------------------172------------------------300
      H&R OE Sport---------------------180------------------------380
      H&R Sport-------------------------180------------------------380
      H&R Sport (29664)---------------200------------------------285
      H&R Race-------------------------315------------------------ 570
      H&R Coilovers***----------------340------------------------380
      Eibach Pro-Kit--------------------102-------------------------277
      Eibach Race----------------------160-------------------------445
      IE SIII----------------------------315-------------------------570
      Koni Coilovers-------------------342-------------------------407
      Cosmo Coilovers----------------450-------------------------560
      Tokico----------------------------165-------------------------265
      TMS J-Stock**-------------------680------------------------1026
      Alpina(est.)---------------------~200-----------------------~350
      FK 60/60 cup kit-----------------379--------------------------379
      Vogtland Standard***--------115/197-----------------------360
      Vogtland CS***---------------137/200-----------------------400
      Vogtland--------------------------225--------------------------360
      **= Alternate rates available
      ***= M3 Application
      Is that a coilover, how much, and where available. I have the H&R Race and hate them, waaaaaaaaaaay to soft for me.
      Originally posted by NavyE30
      I saw Vlad was posting and got excited. Then I saw there weren't any boobs and was sad.
      • fretburnr
        • Jan 2005
        • 1496
        #33
        bill, the J-stocks are not coilovers. they're a stock-size spring. look them up on Turner Motorsports (tms)
        Jay
        • Simon S
          • Oct 2004
          • 3758
          #34
          Originally posted by amdspitfire
          none of these springs are progressive?
          -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
          • rThor432
            • Feb 2007
            • 3907
            #35
            Originally posted by e30cbe
            great compilation thanks
            Yeah that's a copy/paste from the sticky on E30tech.
            • 1991 318is
              • Dec 2005
              • 786
              #36
              Most equations give the following variables necessary to determine spring rate:
              1) material rigidity or torsional modulus
              2) wire diameter
              3) number of active coils
              4) mean coil diameter
              The fourth variable would indicate that all E30 OEM type rear springs are progressive as the mean coil diameter decreases at the top and bottom of the spring. Has anyone ever put these on a checker and checked the second and third inch of compression? Coil overs on the other hand have constant mean coil diameter. Going from a progressive to a non-progressive rear spring would effect handling. Alot of E30's with OEM type springs appear to have more lift to the inside rear than compression to the outside rear wheel.
              • Mr.sexymorningvoice
                • Sep 2007
                • 402
                #37
                has anyone ran the cosmo coil-overs...cause they are really cheap and seem to be a stiffer spring...any opinions?
                • etxxz
                  • Feb 2006
                  • 2085
                  #38
                  ^^ i have them on koni top adj. they are excellent but i have two complaints on them.
                  1. rear springs are 1" too long so i'm not even runnin the adj sleeve on the back so thankfully they sit exactly where i want it. I'm waiting on their 5" springs, but i doubt i'll get them maybe you can ask for them.
                  2. front sleeve is not the same diameter as the strut housing. luckally for me, when i shortened and welded my front struts i welded two more spacers in each that took care of the gap....had to hammer them in for a tight fit. They are Al so be carful
                  their springs rates are 8/10 kg/mm and the combo with koni's is just wonderfull i'm real happy i got it. Extremely streetable, koni's on hard setting and these are even better on the track but even still i run them on soft settings during drift events.
                  these come with some sort of nylon washers/spacers that go on the top and bottom of each spring that takes care squeeks and they adjust with the same kind of adjuster as GC's. i would buy them again. no need to spend another $250 for GC's...use that for your koni fund.
                  No more e30s for me.
                  88 black BMW OBDII 332is dedicated track [sold]
                  88 BMW OBDII bronzit 332is [RIP 03/08]
                  91 BMW 325i [sold]
                  86 Corolla 'Ae86' HB 20v trd [sold]
                  http://youtube.com/watch?v=pTj7Hn9v5Rs
                    • Sep 2007
                    • 402
                    #39
                    i read the writeup on shortening your strut housings, but how long did it actually take you?
                    • gotKRAUT
                      • Apr 2007
                      • 136
                      #40
                      hmm anyone know the Bilstein BTS kit spring rates? or what springs it uses?
                      Kyle Sutherland
                      1995 BMW 540i/6:
                      The Calypso Beast Vid 0-70ish
                      1987 BMW 325es: Face & Butt Lifted/M50tu Swapped*Sold*
                      1985 VW Scirocco: Too many mods, money pit*Sold*
                      • indecline
                        • Sep 2007
                        • 244
                        #41
                        Has anyone heard good things about the BAV AUTO springs??
                        1989 325I(M20B25US)|KAMotors CAI|Bilstein Sports|H&R Sports|ST Sways|SSSquid Tune|Red46 Sump Armor|
                        • gotKRAUT
                          • Apr 2007
                          • 136
                          #42
                          no one? ehh i have searched and searched with no avail
                          Kyle Sutherland
                          1995 BMW 540i/6:
                          • indecline
                            • Sep 2007
                            • 244
                            #43
                            What about Ireland Engineering StageIII springs?
                            • george graves
                              • 19998
                              #44
                              All your questions will be answered if you search...
                              Originally posted by Matt-B
                              • mattmoo60
                                • 30
                                #45
                                I've had the bav auto springs with bilstien sports. it's a spring made by eibach cut for Bavauto. the fronts are pretty solid and the rears are load progressive that tense up under hard turning or heavy braking, but give a little bit on bumps. it makes a still comfortable ride that handles well.
                                they're definitely not the best for performance, but are great for a hybrid, and still significantly out perform stock. price makes them an awesome buy. i'm looking to up grade since i'm boosted and making some serious power.
                                the springs hold their own on my car, but i want a stiffer rear. with that said, i'm probably going to sell mine and upgrade soon. mine probably have 8k miles on em(i'll check later) i can PM you when i'm ready to sell if you're interested.
                                bottom line, it's a good spring with a good price and has it's ups and downs
