Glove box flashlight repair, how to.
  • mcskibadee1
    • Feb 2012
    • 1379
    I know most people don't care because they just have the flashlight there to complete the look or just don't have it at all.
    I wanted the flashlight for originality reasons but also wanted it to work, I know it's just a cool factor at this point. I did a little research and found a write up about how to change out the batteries since the battery is typically the reason the light doesn't work.
    How to write up:
    Link to batteries in the states:
    TRANSACTION FEEDBACK HERE
    FOR SALE ITEMS HERE
  • Poorboyz
    • May 2012
    • 2117
    I just bought a white flashlight and will need to do this. How hard was it to pry the casing apart? What tool(s) and what exact location did you use to pry it open? Thank you for any info you are able to share.
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • e30edward
      • 777
      Once I get the flashlight I'll have to do this. The one in my last car never worked and I didn't bother to fix it.
      • mcskibadee1
        • Feb 2012
        • 1379
        It is glued together so i used a very small screwdriver to slowly pry all the way around. I took my time because the plastic is brittle.
        FOR SALE ITEMS HERE
        • mcskibadee1
          • Feb 2012
          • 1379
          FOR SALE ITEMS HERE
          • Swanny
            • Mar 2012
            • 2834
            4.50 to fix the light?!? You need to be praised sir.
            Swanny!
            SUCKERS.
            • mcskibadee1
              • Feb 2012
              • 1379
              You actually need two batteris so its more around 11 bucks but still cool.
              FOR SALE ITEMS HERE
              • Swanny
                • Mar 2012
                • 2834
                I just get carried away at the thought of a little glove box light
                Swanny!
                SUCKERS.
                • fronton
                  • Oct 2009
                  • 1262
                  I am about to do this but which side to the weld tabs need to be on? positive or negative. I just need a weld tab on one of them correct?
                  • ELVA164
                    • 4861
                    As soon as I got one of these in a parts car I wanted to be able to fix it, and you've come to the rescue! Thanks for this! And +1 on fronton's question.
                    • Herr Faust Schinken
                      • Feb 2012
                      • 3580
                      I didnt know E30s came with flashlights
                      88 325is Five Speed
                      Lachssilber
                      • wikkid
                        • Aug 2012
                        • 113
                        No, the cars were free, with the purchase of a $20,000 flashlight!
                        • fronton
                          • Oct 2009
                          • 1262
                          I did this the other day and have a much brighter flashlight now. Only one of the batteries needs a weld tab on top and the side with the green ring faces down for both batteries.
                            • Feb 2012
                            • 3580
                            88 325is Five Speed
                            Lachssilber
                            • word is bond
                              • Apr 2012
                              • 503
                              Bump. This uses two batteries? One with a solder tab? What about the bulb? Are they widely available?
                              diamantschwarz 1991 318is
