Brake Fluid Flush DIY Video Guide
  • cncmastr
    • 206
    Hi guys,
    I put together another DIY video guide, this time for a brake flush.
    You can view it here: http://www.youtube.com/watch?v=nXMcfzgox6o
    E30 | E46 | E53 | F31
    Collection of my DIY Guides here
  • dnguyen1963
    • Nov 2011
    • 2649
    Well done. Just a minor suggestion...use a syringe to suck out the old brake fluid in the reservoir and replace with the new fluid before you start the procedure...save a couple of minutes.
    • blocke
      • 1305
      Nice work. Just did this the other day, but used a power bleeder. Sucks to lose those bleeder valve covers. Those are like 8 bucks each!
      Parts Wanted
      The Never-ending Resto Mod
      • dnguyen1963
        • Nov 2011
        • 2649
        You can use the little white plastic caps for the closet wire-shelves as your valve covers. They are dirt cheap from Menards or Home Depot.
        • Eufonik
          • Feb 2014
          • 459
          Great video and very descriptive! Going to be doing this when I replace my pads & rotors! I'll be using the video you made for sure haha
          Instagram @prsvere88
          Transaction Feedback
          • markseven
            • Sep 2006
            • 5327
            Be careful when pumping the brakes (when releasing the pedal) that air doesn't get sucked into the system. Ideally you want to close the bleeder before releasing the brake pedal each time.
            I Timothy 2:1-2
