DIY - Wheel Refinishing
  • Joe318is
    • Sep 2005
    • 6451
    Dismount the tires, dont be a weenie
    Originally posted by vlad
      • 34847
      Originally posted by redbull 325is
      what do you do for the rubber shraeder valve? just paint it? buncha tape?
      Julien
      cut it off. any decent tire shop will give you new ones anyway.
      • DarkWing6
        • Apr 2004
        • 7144
        Where do you buy paste or gel paint stipper? And what did you use?
        • Joe318is
          • Sep 2005
          • 6451
          Hardware store, its with the paint, oddly enough
          • nickmp0wer
            • 1427
            My wheel refinish write up
            I saw the other thread about refinishing wheels, and thought i might as well post mine too.
            EDIT - This post was merged from another thread.
            • Joe318is
              • Sep 2005
              • 6451
              DAMN! i like the polished lip, ill have to try that with my 16"ers
              • MitchFong
                • Sep 2005
                • 665
                the balance of your wheels are gunna be out of wack now that you have parts of the lip shaved off, wont they?
                Seems like this would completely throw the wheels off balance.
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  I refinished my 6 spoke aftermarket wheels from curb rash and then painted them. I had no problem with balancing problems.
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
                  • Garageaholic
                    • Dec 2005
                    • 5204
                    It's a long process, but it works, and if it's done right (the DIY way), then they should last a while without pitting. You have to clean and wax them often to keep the luster though.
                    Sand (scuff the surface) with brillo or i used 100grit paper
                    obviously tape what you dont want painted/sanded
                    put 3 coats of etching primer on the wheels
                    wait 3 min between coats, and then put as many coats of paint you want
                    i put 4 coats.. and that was fine
                    I waited till the next day, then put like 5 coats of clear coat
                    waited another day, then sanded the clear coat with 1500-2000 grit paper
                    it really made it shine and got rid of the "orange peel" look of paint, gave it a nice luster
                    i waxed the wheels 1ce a week, and they are still shining
                    check out my pics in my gallery of my red rims
                    Recent Rebranding!!
                    E30 SM62/S62
                    E30 M60 V8
                    E30 M30 Big 6!
                    • Garageaholic
                      • Dec 2005
                      • 5204
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      • MitchFong
                        • Sep 2005
                        • 665
                        mm those wheels are hawt.. so once you done(5 coats of clear coat) and you sand them with 2000grit sand paper, do you need to re-clear coat it? Or does the clear coat stay on after you sand them with the very fine sand paper?
                        • Axxe
                          • Aug 2004
                          • 3355
                          No, do not sand the clear coat.
                          Keep it slideways!!
                          • Garageaholic
                            • Dec 2005
                            • 5204
                            That's why you put 5 coats on.. all you are sanding down is the high spots until it looks smooth. After you sanded it down with 2000 grit, you use car polishing compound to finalize it,, then wax it
                            Its what I did, and it worked great, didn't pit, it shined (with proper care)
                            and i got alot of comments on it
                            the sanding down takes a loong time, so be patient
                            Recent Rebranding!!
                            E30 SM62/S62
                            E30 M60 V8
                            E30 M30 Big 6!
                            • Axxe
                              • Aug 2004
                              • 3355
                              Your wheels look good, but lets not go overboard with "smoothness." They are wheels, subject to chips, high head, curbs and brake dust. They don't have to be perfect, and the longer you spend making them perfect, the longer you will cry when your girlfriend/wife curb it in the mcdonalds drive thru.
                              Keep it slideways!!
                                • 34847
                                if you have to sand down the clear coat to make it look smooth you put it on wrong in the first place. but whatever, your wheels look good.
                                and yeah, no point in making them perfect, nobody will notice a small scratch or chip from 5 feet away, especially when you're moving.
                                also, if my gf/wife curbed my rims she'd be sleeping on the porch!
