DIY: Key Light LED Upgrade
  • JinormusJ
    • 6887
    So, this is fairly straight forward and an extremely easy upgrade. Most people will be able to figure it out no problem, but I thought just to write up this DIY to relieve anyone's confusion over batteries, what LEDs to use, ETC.
    People with the privileged of owning a Lighted BMW key like this one:
    Will quickly find after 25 years, their battery has burnt out or is broken.
    Rather than order a new bulb and battery for $20 from BavAuto and wait 3-5 days in shipping, you can easily upgrade the existing system to work on a lighted LED and battery you can easily find for under $10 at your local electronics store (RadioShack, Metro Electric, etc.)
    What you'll need:
    -Shears
    -1 LED Bulb
    .. - White, Blue, Green, and Yellow LEDs drop at a higher input (3.2v)
    .. - Red LEDs drop at a lower input (1.8v)
    -Coin Sized Battery
    .. -CR1616 (easier to find; not recommended because of slimmer size)
    .. -CR1632 (harder to find; recommended because of larger thickness that matches the OEM battery)
    ... -These batteries are rated to 3v
    -3/64 size Drill bit
    -Power Drill
    -Fingernails
    Let's Get Started:
    1
    Start by opening up the key by pushing the light button roundel in the center and sliding it to the left
    2
    Next, you'll want to open up the central unit by gently applying force with your fingernails on the peice
    3
    Once the unit is opened, the plastic roundel piece that holds the battery will slide out. You can see the spring (-) and the copper filament (+) here in the bottom piece. As observed, my bulb is completely missing.
    At this point, I removed the battery and tested the LED. I opted for a white LED to match OEM standards; just a quick check that the 3v battery powers up the 3.2v LED well. Remember, the longer leg on the LED is the positive (+) leg.
    As you can see, the new battery - CR1632 (pictured left) and the old OEM battery - V625U (Pictured right) are the same height up until the point where the OEM battery has the "extra lump" on top that enters into the Roundel. The "extra lump" is a non-important factor in function, but the general edge heights must be the same to feel OEM (the smaller CR1616 battery will work as well, but will require more force to make contact and activate the LED because of a slimmer edge height)
    4
    Carefully gut the bottom peice and reattach the top peice
    5
    Carefully drill out the hole with a 3/64 size drill bit to facilitate the larger LED
    6
    Afterward, carefully enlarge the circumference of the copper piece by applying force as so. This is done to ensure the new battery has good fitment and does not short on itself when pressed.
    7
    Take your shears and shorten the negative (-) terminal on the LED
    8
    Place the copper filament back into the bottom piece and weave the positive (+) terminal on the LED in between the end of the copper filament (+) as so. Trim the positive (+) terminal as desired.
    9
    Place the spring (-) on to the shortened negative (-) terminal. At this point, you may have to bend the negative (-) terminal down and the positive (+) terminal up so that the spring doesn't short on the positive (+) terminal. At this point, you can opt to solder the LED onto the spring (-) and copper filament (+) if desired. I did not as the assembly pressure is enough to hold the LED into place and would make for easier replacement down the road if something were to happen to the LED.
    10
    Place the new batter inside the roundel, and then refit the roundel into the top portion of the central unit
    11
    Reassemble the central unit and test as desired
    12
    Replace central unit into the key by depressing the roundel and sliding it back into place
    Notes
    -A Red LED will light up brighter that the white LED because of the lower input drop of the Red LED. Only 1.8v is required to light it and a 3v battery will cause it to burn hotter and have a higher light output. If you don't mind the Red color and want a brighter light, you can opt to change out to a Red LED.
    Testing from about a foot away at night.
    PERFECT!
  • Albuquerque30
    • 1349
    Nice writeup! I have an amber LED that I put in mine a couple years back. One of my favorite things I've done. Haha.
    WTB NorCal: Z4 shifter + misc. parts
    • GreasyE30
      • Dec 2012
      • 159
      Very cool. Nice Write up
      2006 Dodge Magnum SRT8
      1986 Slammed Shwarz ETA Coupé (DEAD)
      2004 Slammed TSX A/T (Wifey's)
      1963 Slammed ChevyII never ending project
      1982 Suzuki GS1100GK CaféRacer
      • Blackout
        • Apr 2011
        • 4130
        I like!
        » PARTS FOR SALE
        » TRANSACTION FEEDBACK
        • ethirtydavid
          • Jan 2008
          • 2331
          great bench project, these pictures should help people get started. nice work
          • phillye30fanboy
            • Apr 2012
            • 120
            Did it, it's so sweet.
            • mattscrog
              • May 2013
              • 27
              I would love to do this so I can finally use that key. However, my key does not open the same way and looks a bit different. Wish I had a picture to put up. Any ideas? Do you think it would be pretty much the same?
              thanks
              -mattscrog
              • JinormusJ
                • 6887
                Post a picture and I'll do my best to help
                • Eric
                  • 5142
                  I've been meaning to do this, thanks for the battery part numbers!
                  • lancelotti
                    • Jun 2013
                    • 4866
                    Did it today!!! Great thread.
                    • deeze30
                      • May 2013
                      • 298
                      The key that was given to me by the previous owner was the valet key that only works with the cars trunk. Would you happen to know where i can get this type of key fob? Great diy btw really interested on making one for myself but i need the key fob
                      • agent
                        Vice Grand Pubaa
                        • 7960
                        The dealer can cut/order you one with the vehicle's VIN and proof of ownership.
                        Originally posted by kronus
                        • DetailAddict
                          • Apr 2011
                          • 245
                          nice! now i just need one of them keys... :D
                          • deeze30
                            • May 2013
                            • 298
                            Any idea how much would that run me?
                            • agent
                              Vice Grand Pubaa
                              • 7960
                              Depends on the dealer. I think I paid $35 or $40...?
