DIY Battery cable ends
  • grt
    • Apr 2011
    • 246
    Deleted
    Track car
    http://www.r3vlimited.com/board/showthread.php?t=2214204
    Street car
    http://www.r3vlimited.com/board/showthread.php?t=307890
  • Gregs///M
    • Mar 2012
    • 2459
    I normally hate to bash other peoples threads but I have to say that I would not recommend this DIY for making battery cables.
    The OP use pliers as his crimper instead of crimpers designed for the lug and wire. There is no strain relief, and those run lug types will surely fail. I have seen it many times in my professional career.
    Should this connection fail, while connected to the battery, it will no doubt cause a vehicle fire. I would hate to see a member's car catch fire because of a poor battery cable connection failing and falling onto electrical ground.
    A proper 4AWG crimping tool should be used and a higher quality ring lug should be used also. Also can substitute set screw type ring lugs instead of crimping.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • bmwguy325is
      • May 2011
      • 1263
      I agree with the proper use of terminal end and crimp tool.
      When I did my double ought wire install for a stereo we had to use a mallet and punch tool to crimp the wire end.
      Further more and it takes a bit of time solder that entire end to the terminal crimp.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
