Acronyms
  • f u z z
    • 1600
    FUPA - Fat Upper waffleswaffleswaffleswaffleswaffles Area
    • DaN
      • 1265
      A - processed vehicle speed signal
      A - "out" (Aus)
      AB - Airbag
      ABL - Brake system warning Lamp (2 color)
      ABS - Anti-lock Braking System
      AC - Air Conditioning (from ETK)
      ACC - Active Cruise Control
      ACS - Active Comfort Seats
      ADB(X) - Automatic Differential Braking
      ADS - engine intake air control
      ADV - windshield wiper pressure control
      AEGS - Automatic Electronic Gearbox Control (also EGS)
      AFM - Air Flow Meter
      AGD - suction silencer (from ETK)
      AGR - emission reduction
      AGS - Adaptive transmission control
      AG - Automatic Gearbox (transmission)
      AHK - Active rear-axle Kinematics
      AHK - trailer hitch (from ETK)
      AHM - trailer Module (not for US models)
      AHPS - Advanced HPS
      AIC - Automatic Interval Control (rain sensor)
      AKF - activated carbon canister (from ETK)
      AKS - Active head restraint
      AKS - pressure regulating device (from ETK)
      ALC - Automatic Light Control
      ALR - Automatic Lamp Range Adjustment
      AMM - Air Mass Meter
      AMP - radio system AMPlifier
      ARI - car radio information system (from ETK)
      ARS - Active Roll Stabilization
      ASC - All Season traction
      ASC-EZA - ASC w/ engine timing and injection intervention
      ASC+T - ASC+ Traction control
      ASK - Audio System controller (Kontroller)
      ASR - self starter block relay (from ETK)
      AST - Automatic Slip control (marketing term)
      AT - remanufactured part (from ETK)
      AT - Antenna (from ETK)
      ATF - Automatic Transmission Fluid (from ETK)
      ATL - exhaust gas turbo charger (from ETK)
      AUC - Automatic air recirculation
      AUT - AUTomatic transmission (from ETK)
      AVT - Antenna amplifier Tuner
      AZD - tightening torque specifications (in TIS)
      A/D – Analog/Digital
      B - Benzene (gasoline)
      BAT - BATtery (from ETK)
      BC - Board Computer
      BC1 - Body Controller 1
      BL - Brake Light (from ETK)
      BLS - Brake Light Switch
      BMBT - Board Monitor
      BS - Block diagram
      BST - Battery Safety Terminal
      BVA - Brake pad wear indicator (from ETK)
      BZM - center console control center
      BZMF - center console control center, rear
      CAN – Controller Area Network (Multiple ECU Controller)
      CAN-Bus - Controller Area Network (bus)
      CANH-Bus - CAN bus, High
      CANL-Bus - CAN bus, Low
      CANP - fuel tank ventilation valve
      CAS - Car Access System
      CBC - Corner Braking Control
      CBS - Condition Based Service
      CCM - Check Control Module
      CD - Control Display
      CDC - Compact Disk Changer
      CDS - CD player (from ETK)
      CEL - CELsius (from ETK)
      CIM - Chassis Integration Module
      CO - Carbon monOxide (from ETK)
      COMBI – Electronic Instrument Cluster
      CON - CONtroller
      CU - Copper (from ETK)
      CVM - Convertible top Module
      CVT - Constantly Variable Transmission
      CW - drag coefficient (from ETK)
      D1 - Xenon light/ gas discharge (from ETK)
      D-Bus - Diagnosis bus (same as TXD)
      DBC - Dynamic Brake Control
      DBS - Dynamic Braking System
      DCS - Dealer Communication System
      DE – Diagnostic Unit
      DD - Dynamic motor Drive
      DDE - Digital Diesel Electronics
      DIN - German industrial standards
      DIS - Diagnosis and Information System
      DISA - Differential air intake control
      DIVA - continuously variable length intake runners
      DK - throttle housing/valve
      DKB - throttle w/ brake intervention
      DKE – Throttle Increase
      DKI - throttle position
      DKR - throttle reduction
      DKT - throttle position signal
      DKV - preset throttle position value
      DME - Digital Motor Electronics
      DM-TL - Diagnostic Module Tank Leakage
      DOHC - Double Over Head Camshafts (from ETK)
      DS - gasket set (from ETK)
      DSC - Dynamic Stability Control
      DSP - Digital Sound Processing
      DTC - Diagnostic Trouble Code (SAE)
      DTC - Dynamic Traction Control
      DWA - theft deterrent system
      DWS - tire pressure Warning System
      DZM - revolution counter (from ETK)
      E - "in" (Ein)
      EBA - installation instructions (from ETK)
      EBV - Electronic Brake force proportioning
      ECE - European market version (from ETK)
      ECM - Engine Control Module (SAE term)
      ECU - Electronic Control Unit
      EDC - Electronic Damper Control (from ETK)
      EDR - Electronic throttle control
      E-KAT - Electrically heated catalytic converter
      EZA - see ASC-EZA
      ECO - Controller for I-Drive system
      EDC - Electronic Dampening Control
      EDC-K - Electronic Dampening Control - Continuous
      EDK - Electronic throttle valve
      EDS - pressure regulator
      EFH - Electric window lifter (from ETK)
      EGS - Electronic transmission control
      EH - Electronic-Hydraulic
      EHC - Electronic Height Control
      EKM - Electronic body Module
      EKP - Electric fuel Pump
      ELV - Electronic steering lock
      EM - Electro-Mechanical
      EMF - Electro-Mechanical parking brake
      EML - Electronic Motor Load regulation
      EMV - Electro-Magnetic sensitivity (from ETK)
      EO - component location
      EPC - Electronic Parts Catalog (also ETK)
      EPROM - Erasable/ Programmable chip Memory (from ETK)
      ETK - Electronic parts catalog (also EPC)
      ETM - Electrical Troubleshooting Manual
      ESS - Electronic anti-theft device
      EV - injection Valve
      EWS - Electronic drive-away protection
      FB - Function description
      FBC - Fading Brake Control
      FBD - remote control services
      FBZV - radio frequency locking system
      FGR – Vehicle Speed Control (Cruise Control)
      FH - window lifter
      FHK - rear Heater/ air conditioner
      FLC - automatic Light Control
      FRU - Flat Rate Unit
      FS – Crash Sensor
      FZV - central lock receiver
      GAL - speed dependent sound volume
      GM - General Module
      GMR - yaw moment control
      GPS - Global Positioning System
      GRII - cruise control
      GRS - rotation Rate Sensor
      GS – Belt Tensioner
      GWK - torque converter lock-up control
      H - "rear" (Hinten)
      H2 - Xenon headlights
      HA - rear Axle (from ETK)
      HC – Hydro Carbon
      HD - Heavy Duty (from ETK)
      HDC - Hill Decent Control
      HFM - Hot Film air mass Meter
      HG - manual Gearbox (transmission)
      HKL - Hydraulic trunk lid Lift
      HLM – Hot Wire Air Mass Meter
      HPS - Head Protection System
      HR - Heater control (from ETK)
      HVA - Hydraulic Valve Adjuster (from ETK)
      Hz – Hertz (Cycle)
      I-Bus - Information bus
      IB - Interior lighting control signal
      IHKA - automatic Heating and A/C
      IHKAF - IHKA w/ micro filter
      IHKR - regulated Heating and A/C
      IHKRF - IHKR w/ micro filter
      IHKS - standard Heating and A/C
      IHPD - Internal High Pressure Deformation
      IHR - Integrated Heater control (from ETK)
      IKE - Instrument cluster Electronics
      ILH - Interior Lighting, rear
      ILV - Interior Lighting, front
      IMS - Instant Mobility System (from ETK)
      IR – Infrared
      IRS – Infrared Locking System
      ISC – Idle Speed Control
      ISIS - Intelligent Safety Integration System
      ISN - Individual Serial Number
      ISOFIX - standardized mounts for child restraints
      ITS - head airbag assembly/ Inflatable Tubular Structure
      IVM - Integrated power supply Module
      K-Bus - body bus (Karosserie)
      KAT - catalytic converter
      KATON - converter creating (signal)
      KD - Kick-Down
      KHI - interface for headphones
      KL - terminal designation
      KL15 - run bus (ignition switch run position)
      KL30 - battery bus (hot at all times)
      KL31 - ground bus (chassis ground)
      KL50 - start bus (ignition start position)
      KLR - accessory bus
      KO - compressor "on" signal
      KOMBI - instrument cluster
      KOREL - compressor relay signal
      KR – Contact Ring
      KSK - Knock Sensor
      KVA - fuel consumption signal/value
      KW - crankshaft
      KW - KiloWatt (from ETK)
      LCM - Lamp Check Module
      LDP - Leak Diagnosis Pump
      LEV - Low Emissions Vehicle
      LEW - Lateral acceleration sensor
      LHD - Left-Hand Drive (from ETK)
      LKM - Lamp control Module
      LL - closed throttle
      LM - Light Module
      LMM - air flow meter/sensor
      LMR - Light alloy wheel
      LRA - vertical headlight aiming
      LSM - steering column memory
      LSZ - Lamp Switching center
      LVA - air supply system (for EHC system)
      LWR - vertical headlight aim control
      LWS-5 - steering angle sensor
      M-Bus - IHKA/IHKR stepper motor bus
      MAL - center armrest
      MBC - Maximum Brake Control
      MDK - Motorized throttle valve/system
      MFL - Multi-Function steering wheel
      MFC - Multi-Function Controller
      MFU - Multi-Function Clock
      MID - Multi-Information Display
      MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp
      MIR - Multi-Information Radio
      MMC - Multi-Media Changer
      MoDiC - Mobile Diagnostic Computer
      MOST-Bus - Media Oriented System Transport bus
      MRS - Multiple Restraint System
      MSR - engine drag torque Regulation
      MV - Magnetic Valve (solenoid Valve)
      n-ab - rotational speed, transmission (rpm)
      n-mot - rotational speed, engine (rpm)
      NAVI - Navigation module
      NG - New Generation (as in N73 engine)
      NG - tilt sensor
      NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK)
      NSD - rear muffler (from ETK)
      NSL - rear fog Lamp (from ETK)
      NSW - fog lamp (from ETK)
      NTC - Negative Temperature Coefficient
      NW - camshaft (from ETK)
      OBC - On-Board Computer
      OBD - On-Board Diagnosis (SAE)
      P/N – Park/Neutral position
      P-Bus - Periphery bus
      PB - Pin assignments
      PBS - Parts Bulletin System (in TIS)
      PDC - Park Distance Control
      PGS - Passive Go System
      PM - Power Module
      PP – Impact Pad
      PTC - Positive Temperature Coefficient
      RLS - Rain-Light Sensor
      PWG - Pedal position sensor/ potentiometer
      RA - Repair instructions (in TIS)
      RAM – Random Access Memory
      RAL - Aluminum wheels (from ETK)
      RAL - standard color (from ETK)
      RDC - tire pressure Control
      RDS - Radio Data-broadcast System
      RDW - tire pressure Warning
      RHD - Right-Hand Drive (from ETK)
      RM - Relay Module
      ROZ - Research Octane rating/ fuel grade (from ETK)
      RPA - tire puncture warning (from ETK)
      RPS - Rollover Protection System
      RS - Repair kit (from ETK)
      RSW - back-up lamp (from ETK)
      RXD - wake-up Diagnosis line
      RZV - direct stationary ignition
      SASL - Satellite, A-pillar left
      SASR - Satellite, A-pillar right
      SAV - Sport ACTIVITY Vehicle
      SB - fuse assignments
      SBE - Seat occupancy detector/sensor
      SBFH - Seat module, passenger-side rear
      SBSL - Satellite, B-pillar left
      SBSR - Satellite, B-pillar right
      SBT - SI techniques/ tech reference information (in TIS)
      SCA - Soft Close Automatic/Actuator
      SD - sliding roof (from ETK)
      ZV - central locking system
      ZS - central lock (from ETK)
      ZSD - center muffler (from ETK)
      ZV - central locking system (from ETK)
      ZVM - central locking Module
      ZWD - idle control valve
      • Blister
        • Feb 2006
        • 163
        GUNT - Gut and waffleswaffleswaffleswaffles combined. Similar idea to FUPA
        • ///M Powered
          • Jan 2004
          • 1109
          DUFF
          designated ugly fat freind
          • OptimusGlen
            • Oct 2005
            • 142
            dunno if it's been posted yet or not...
            TLA three letter acronym
            • m42technic
              • 1056
              DaN, I cant believe you copied the entire BMW acronym sheet. :p
              James Peacock
              WWFSMD?
              • Hatchman
                • Mar 2005
                • 1425
                POS -------- Piece of shit
                ROFFYMIA -------- Rolling on the floor F***ing your mother in the ass (Ive actually seen it used before)
                IMO / IMHO------- In my opinion / in my humble opinion
                • DaN
                  • 1265
                  Not the entire list, too many characters to copy. So I left a few out.
                  :up:
                  • BahnE30
                    • 1050
                    Originally posted by DaveCN
                    Charlie has one in his sig - or did.
                    FYYFF
                    Foreign Youth Yearn for Freedom??? i don't get it????
                    • E30 Wagen
                      PO - Previous Owner
                      • dirty30
                        • 3048
                        so...anyone wanna 2186?...224?
                        • tabasco
                          • Mar 2006
                          • 861
                          I cannot believe that nobody has posted up...
                          DILLIGAF = Does It Look Like I Give A F#$k
                          jason
                          • Intense
                            • Mar 2006
                            • 292
                            SI = Service indicator
                            _-_-_-_-_-_-_-_-_-_-_-_-_
                            Past: lots of stuff
                            Present: e46 m3
                            2010 F150 Lariat
                            1990 E30 Touring
                            1/4 e34 LeMons car
                            2004 Malibu 23 LSV
                            2000 Odessey Millenia 210
                            • YAN-3
                              • Jan 2004
                              • 6018
                              DDE FTW!
                              • Mastrcruse
                                • Sep 2005
                                • 5340
                                GILF Grandma I'd like to F*ck
