What I did for my non airbag '90 cabby-
Dont know about the HP line, I'm not using PS. From what I gathered though, people were able to use their e30 line somehow.
Using spacers I cut for the rack, and the knuckle, it went together fine but had tight spots I found at the first U joint out of the firewall self clearancing a little. Some file work on the edges and it's all good. You're going to need to cut the linkage and space it otherwise the linkage will be too long and the splines lock screw (at the rack) will not locate properly.
Im using offset cabs and the whole e36 rack assembly including tie rods.
Dont mind the mess, I cleaned up shortly after I took the pic :D
