How To Guide - E36 Steering Rack Swap
  • itskingsteelo
    • Jul 2013
    • 1340
    #976
    Do you have any pictures of the difference in the angle?
    Originally posted by dvck
    • JinormusJ
      • 6887
      #977
      Unfortunately, no. It never occurred to me to document it. Sorry
      • BMW B3 2.5
        • Jun 2010
        • 52
        #978
        Anyone installed a 95-97 E36 Z3 1.9L 2.7 Turns steering rack on a DD e30 ?? Or is there a better one for a DD car ?
        • jalopi
          • 2370
          #979
          IMO go with the e46 fast rack. Not sure which one it is, after a certain production date all of them are the quick kind. Marginally slower than a z3 rack, not super twitchy going straight down the road. At least for me anyway, I couldn't stand my z3 rack.
          • Madhatter
            • Oct 2004
            • 966
            #980
            purple tag, "067" last 3 digits in the part number.
            Just a little project im working on
            - http://www.lse30.com -
            • Golfer_705
              • Aug 2011
              • 59
              #981
              Rack identification
              Awsome write up! My parts for 84 coupe just showed up. I ordered a Z3 2.7 L2L rack. I got the rod ends on and went to center the wheel and realized the rack 3.2 lock to lock. Could someone please help me identify what this rack really is. The part #'s on it are 7852 995 306, 1096240, 003208 and 0198. I called the supplier back they tell me it is an e36 Z3 M rack. I don't believe this is right. Can anyone confirm or dispute what i was told? I ended up getting a used e36 rack to put in the car in the mean time. The used rack has the same part numbers on it as first one so any help identifying it would be great!
              Used rack is in the car now, only modification needed to fit was 2 BMW spacers 72111847480 turned in a lathe to 9/16" tall as upper rack mount spacers. My steering knuckle needed no modifications to fit. Factory e30 high & low pressure lines fit perfectly. Whatever the rack is its a big improvement from stock.
              What steering rack is Part # 7852 995 306
              • MC Hammered
                • Jul 2008
                • 2076
                #982
                After spending a couple of days reading up on steering rack options, then speaking do DS Rook about his z3 rack upgrade he did in his vert, I have ordered an e46 ZHP rack with e30 tie rods from rackdoctor.net for my vert.
                Can't wait for this setup to arrive and looking forward to comparing it against the z3m rack in the touring.
                My 1989 e30 s52 Touring... this is Betty
                My 1989 325i vert (sold)...this is Nina
                My 1991 M5 (sold)... this is Veronica
                Photo comparison: OEM vs aftermarket windscreen for a convertible
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  #983
                  whats the difference between the e36 and e46 racks ?
                  Alice the Time Capsule
                  • jalopi
                    • 2370
                    #984
                    the rack ratio. in terms of fastest racks we can swap into our cars, it's the second fastest. Only marginally slower than the z3 rack, but it's a progressive rate aka driving on a bumpy / pot-holey road isn't a nightmare.
                    For a car that only gets track use I would use the z3 rack. For normal people that drive their cars on the street, get a progressive rack.
                    • MC Hammered
                      • Jul 2008
                      • 2076
                      #985
                      From the reading I have done the e46 racks are linear, not progressive rate and there is a difference between the regular e46 and the ZHP version.
                      • Wanganstyle
                        • 2828
                        #986
                        E46 rack is linear; many model e46's got the same part number rack as the Zhp cars.
                        Z3 rack has less angle than other options; track cars can benefit from more angle; I know it's saved my ass more than once.
                        We are running a z4 rack in the full race e30; I've ran z3 before and prefer z4. It's the same ratio of turning but has MORE ANGLE. E46m is also a quick ratio rack with more angle than the z3
                        • ebox86
                          • Sep 2012
                          • 528
                          #987
                          Do you have to put the spacer on the top of the rack? I installed my spacer on the bottom of the rack to raise it up for clearance of the firewall hole. Does this cause any adverse affects?
                          '99 e46 323i - wrecked
                          '87 e30 325iS - sold
                          '91 e30 325i - sold
                          '89 e30 M3 - fun car
                          '09 e91 328i - sold
                          '97 impreza - rally car - flipped
                          '08 impreza - new rally car
                          '01 996 tt - more fun car
                          '82 Ford f350 - work truck
                          • FLG
                            • Sep 2011
                            • 3165
                            #988
                            Yes, increased bump steer.
                            Sent from my SCH-I545 using Tapatalk 2
                            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                            • johhntyrouts
                              • Jun 2014
                              • 1
                              #989
                              My guide for E30
                              Hi mate , my mate had an e30 and so do I . (although I like the e30 rack at the moment, it will. BE getting upgraded)
                              He fitted the e36 rack , but another commen one is a z3 rack.
                              I believe he just 'made' the standard power steering pipes fit . The pump was the same I think.
                              You can also look into getting e36 rack spacers , he had silly lock for fairly cheap xD...
                              If you want any informaion about Classified WEbsites then you can join us
                              Top ten Classified websites
                              • Luke318is
                                • Feb 2007
                                • 69
                                #990
                                didnt have time to order any hardware, so im going to be making a trip to the hardware store!!
                                which step uses these?
                                Bolt M10x50 - - - - - - - - - 26111226737 - - - - x2 - - -$2.70
                                is it step 24, bolting the rack back onto the subframe with the short spacers?
                                Sig Pic Outdated
