How To Guide - E36 Steering Rack Swap
  • Haystack
    • Mar 2014
    • 213
    #1126
    I'm currently in the middle of this. Got the rack a while ago, this line, do I need to crimp both ends of it? The one side popped off quite easily. Also, how should it be ran? Will it hug the subframe or should I worry about pinching it?
    • Haystack
      • Mar 2014
      • 213
      #1127
      Another pic of the line.
      Sent from my iPhone using Tapatalk[/QUOTE]
      • Powling
        • Jan 2015
        • 1290
        #1128
        I've been searching but haven't found the definitive answer yet...but with airbag cars, spacers on the bottom of the rack mean I don't have to modify the firewall correct?
        Steve • Toronto
        1991 318is • Brillantrot
        Build Thread
        • Powling
          • Jan 2015
          • 1290
          #1129
          Anyone? Hoping to get the rack finished up and installed tonight.
          Steve • Toronto
          Build Thread
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #1130
            Air bag cars just need the subframe spaced iirc
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • Powling
              • Jan 2015
              • 1290
              #1131
              Subframe spaced? Thats the first I've heard of that, I thought it was only the steering rack that needed spacing?
              Steve • Toronto
              Build Thread
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #1132
                Thats what i meant my bad. Just space the steering rack in the subframe
                • Haystack
                  • Mar 2014
                  • 213
                  #1133
                  Steering rack spacers on the subframe. That's what he meant.
                  • Powling
                    • Jan 2015
                    • 1290
                    #1134
                    Correct - but what I'm wondering is if the spacer goes above the rack or below the rack. The attached diagrams show both options.
                    I just haven't found a definitive answer to which option is better, and if the bump steer is really an issue.
                    BELOW
                    I've read that by putting the spacers below the rack, it raises it enough that you don't have to cut the firewall, but it gives nasty bump steer
                    ABOVE
                    Apparently putting them above means you have to cut the fire wall, but you get far less bump steer.
                    Steve • Toronto
                    Build Thread
                    • Powling
                      • Jan 2015
                      • 1290
                      #1135
                      Sorry to resurrect this thread again - but how in the hell did everyone get the rubber boot off the steering shaft in order to dremel the firewall? I'm doing the swap with the car on jack stands and I can't get enough leverage / figure out a way to get the rubber boot off to expose the firewall.
                      Thoughts?
                      Steve • Toronto
                      Build Thread
                      • Powling
                        • Jan 2015
                        • 1290
                        #1136
                        Thoughts?
                        Bump - anyone?
                        Steve • Toronto
                        Build Thread
                        • z28
                          • Oct 2014
                          • 362
                          #1137
                          I removed the steering wheel column boot with some pliers and a screwdriver, I thought the boot was going to rip because it was stuck on there good, but it survived.
                          First e30 - 1991 318i 4 door
                          • Powling
                            • Jan 2015
                            • 1290
                            #1138
                            Good to know, thanks for the input.
                            I was worried pulling on it that it would tear. I'll give it another shot with more muscle.
                            Steve • Toronto
                            Build Thread
                            • Powling
                              • Jan 2015
                              • 1290
                              #1139
                              I've run into another snag here...
                              ...for an airbag car, I am reusing the e30 PS lines rather than getting the e36 resivour and his pressure PS line...but I can't figure out how the 'coiled' PS line is to be run? The line I am talking about is highlighted yellow in this diagram.
                              Steve • Toronto
                              Build Thread
                              • mtech325
                                • May 2008
                                • 559
                                #1140
                                For the high pressure line, I believe I just used an m20 high pressure line and bent it to fit. Granted I was doing a 24v swap at the time, so perhaps the coiled line can work better with the m42 space confines.
