How To: Coilovers and strut tube modification (with pictures!)
  • blueapplesoda
    • Dec 2005
    • 1904
    #226
    Originally posted by bimmerteck
    I generally use a table spoon or two of ATF in the bottom of each strut tube. The master tech who told me to do so never told me why though to my knowledge.
    What I read somewhere is that it increases surface area contact with the outer tube allowing the shock to use the outer tube as a heat sink.
    By all means it makes sense as a shock absorber converts motion energy into heat energy by means of liquid/gas/mechanical friction. But do they really get that hot?
    And yes, two metals in contact for long period of time without some sort of corrosion inhibiting substance could become chemically welded.
    • !kid
      • 1362
      #227
      Originally posted by blueapplesoda
      What I read somewhere is that it increases surface area contact with the outer tube allowing the shock to use the outer tube as a heat sink. By all means it makes sense as a shock absorber converts motion energy into heat energy by means of liquid/gas/mechanical friction. But do they really get that hot?
      i was reading through one of my ASE books. adding oil (preferable red ATF) to our style of front strut housing/ shocks is highly suggested because of heat. the amount of oil need is enough to reach the top after the shock is inserted into the strut housing. if oil is not added the life of the shock is can be shortened.
      :borg:
      • wille28
        • 113
        #228
        my ix are 3 inch shorter than the oem one and i have the hd i will cut my housing this week and give you feedback i will run no spacer
        • Moto-Mucci
          • 2058
          #229
          I would strongly advise not cutting 3" off your housings...
          You should read this whole thread first.
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            #230
            If you run Bilstien HD shocks like that you will blow them out instantly, they won't make it 5 miles.
            • wille28
              • 113
              #231
              why? what i have to do?
              • wille28
                • 113
                #232
                i have a coilover sleeve ans short spring btw
                • penneroyal
                  • 209
                  #233
                  I see the OP had 3" from perch to the top of the strut tube. Is that what everybody is setting the perch at? Any suggestions? I have the GC kit, 6" 600# springs FYI.
                  Also, When you guys are cutting your housings, are you removing the 1" section above or below the stock mounted spring perch?
                  Help much appreciated! working on my housings as i write this!
                  THE ACURA TL PROJECT
                  BUFF ENUFF? STYLE.OVER.COMFORT
                  DURTY 3ER///STYLE.OVER.COMFORT
                  • AsharC
                    • Jun 2011
                    • 1508
                    #234
                    Im confused.
                    When he was talking about the shock how its 4" long and he cut 1". Why does he need a spacer? I am not understanding it.
                    BUY MY WHEELS! BBS E50s!!
                    http://www.r3vlimited.com/board/showthread.php?t=275407
                    Originally posted by Lurker27
                    Any man will tell you being blown is better than being stroked.
                    • David325is
                      • 194
                      #235
                      The short body Koni shock is 4" shorter than a stock shock or Bilstein. Thus a 4" spacer is needed. It is installed at the bottom of the strut tube housing. Modify the housing and this spacer to go lower.
                      If you remove a 1" from the housing, you remove a 1" from the spacer.
                      If you remove 2" from the housing, you remove 2" from the spacer. ETC
                      Remove more material to go lower, but I would not remove more than 2.25".
                      • Moto-Mucci
                        • 2058
                        #236
                        You don't need to remove any more then 1.5"
                        1.5" chopped off with the GC kit and you'll have your skid plate a hair off the ground, if at all.
                        Here's a good comparison - Mine housings (red car) were chopped 1.5" with the GC kit. Shown, they had about another 1.25" of thread left. It was a fully functional drop with room to really hammer it to the ground if you don't like functionality.
                        Patrick's car (white) was aired out in this photo, resting on the S50 skid plate. I believe the S50 hangs a bit lower then the M20, however you at least get a comparison of what kind of clearance you have. Keep in mind the M20 oil pan hangs lower then the "I" valence.
                        • T La
                          • Dec 2009
                          • 190
                          #237
                          question, what have people been using as the perch for the adjuster, it looks like some people are using a section of piping, while others are just sectioning out the housing from below the stock perch and just re-using a ground down stock perch. Is this correct?
                          • downernsp
                            • Mar 2008
                            • 1932
                            #238
                            That is all on your choice of hardware. I used a round bar stock with the ID to be the same as the OD of strut housing. One thing I would say is this please please make sure whatever you do use to be the same thickness on the thread on sleeve that way you can a sure the sleeve will sit properly.
                            • Moto-Mucci
                              • 2058
                              #239
                              The GC kit also comes with a weld on perch.
                              • E30SPDFRK
                                • 5709
                                #240
                                If you're using IX HD's, cut 2" off. The HD's have large bumpstops and the piston doesn't go all the way into the housing. Koni's may be different, I don't have experience with them.
                                False. I used mine for 12,000 miles before I got them revalved and they were still good.
                                Byron
                                Leichtbau
