That doesn't mean you should use HD's...
					How To: Coilovers and strut tube modification (with pictures!)
 This is true as told to me by my father who is a master tech. But it does not apply to bilstein sports/hds as they are inverted and the actual shock housing is partially exposed to open air. Also the oil is bad for the bumpstops. The bilstein instructions tell you to not use oil.What I read somewhere is that it increases surface area contact with the outer tube allowing the shock to use the outer tube as a heat sink.
 By all means it makes sense as a shock absorber converts motion energy into heat energy by means of liquid/gas/mechanical friction. But do they really get that hot?
 And yes, two metals in contact for long period of time without some sort of corrosion inhibiting substance could become chemically welded.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
 www.gecoils.com
 My euro 316 project Transaction FeedbackComment
 um, no, not really
 the ones on the left are shocks, to the right are struts. see the difference?
 E30s have shock inserts for the fronts.
 regular shocks for the rear.E30 LS1 swap, Tremec TKO, three link live axle rear suspension.Comment
 This is a rode less traveled. I'm not going to give away my trade secrets on how i shortened the bilstein sports. Every part of my coilover setup is offered for sale by me.
 First we shorten the strut tubes 1.9" and add a collar along with AKG sway link tabs. Welding done by Chris Castro of Castro Motorsports.
 Pics installed with my GE camber plates and coilover dust boots. 6" #300 springs
 Rear installed with GE tall RSMs 4" #800 springs (14lbs of boost and a stereo system makes the car squat hard)
 Rear all the way down and fronts all the way up. Will be switching to 7" springs
  Last edited by einstein57; 08-11-2011, 09:37 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. Last edited by einstein57; 08-11-2011, 09:37 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
 www.gecoils.com
 those rear mounts are a great idea. i have to measure mine to see if ill need them for full travel. chris does a great job on those front strut housings recently got mine done.Comment
 Yup. Pre production models. The mass produced units will not be red and gold. They will consist only of the colors found on the hood emblem (black sleeves to hide dirt in the nooks and crannys, silver adjusters so you won't mar them and make them look crappy, blue springs cause I like them)Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
 www.gecoils.com
