i did some reading and it said that on the strut housing the car has less leverage on the sway bar making a smaller bar "feel" like a larger one. is this correct?
					How To: Coilovers and strut tube modification (with pictures!)
 Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
 DIVING BOARD DIVISION DIVISION IDIOT
 I love sitting down and just driving!Comment
 IMO they should fit tight. The Camaro version of their front coilover kit fit very tight....
 However it also shouldn't hurt anything if they don't. You will simply make it easier to adjust them if they are tight.sigpic
 88 325isComment
 awesome info in here.
 I just bought the GC conversion kit with G60 front billy sports.
 Has anyone found out where to get a neoprene sleeve that's only a mill thick? That seems like a hard find. Electrical tape is messy as fuck after a month or so.
 Maybe hockey tape? I don't know how long that lasts though. Haven't played since I was 8...
 Also, does anyone sell super low profile helper springs? The ones pictured on pg 6 look like they add over an inch of ride height.Last edited by Moto-Mucci; 02-02-2009, 01:27 PM.Comment
 In Chicago, sealing up the sleeves might not be a good idea. You may end up with water/salts trapped between the sleeve and the housing, which will make a great home for rust to start eating your housings, and you will never know...until it's too late.
 Ground Control has HELPER springs which are only about 15mm compressed.Comment
 Hmm good point.
 I wonder if I could maybe just add a couple extra layers of paint to the bilsteins to make up a couple mm's.Comment
 ...probably your best bet.
 How 'bout Plasti dip?Comment
