13 Button OBC Tricks & Easter Eggs
  • Super Sedan
    • Feb 2006
    • 551
    #121
    Originally posted by oldskool3
    Thats why. My temp always reads -30oC. Thanks
    Now time to get a new exterior temperature sensor.
    • e30slut
      • May 2008
      • 793
      #122
      Originally posted by delatlanta1281
      Shit ok! Jeez sorry for pissing you off. You guys know about pushing in the blinker stalk right?
      just found this out a few weeks ago...
      I'm gonna go make the alarm go off..
      • e30slut
        • May 2008
        • 793
        #123
        kust made the alarm go off and couldnt figure out how to shut it the fuck up!
        so i locked the door figuring that it would eventually go off, and it did as soon as the lock engaged...
        • bmwstephen
          • 2463
          #124
          anyway to make the OBC code function a permanent thing instead of having to reenter after every use ?
          • M42Power
            • Dec 2009
            • 519
            #125
            Does anybody in the us want to trade a 12 button obc + harness for a mint euro analog clock?
            Originally posted by kendogg
            Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
            OG RACECAR
            • BMWManiac
              • Dec 2010
              • 1091
              #126
              Is the main harness and the OBC the ONLY things you need to have ALL the features work? I installed the 13 button OBC, but all I can see if time/date and I think the mph. Everything else reads "PPPP." I've googled, searched R3vlimited, e30tech, and they all have a list of tricks to do but nothing has worked. I'm at the point where I think I should replace it. But I'm just curious if you need any of the other parts plugged in to?
              1997 Artic Silver M3
              CES GT4094r 651hp/615tq @ 24 psi
              • MaxBell
                • 1391
                #127
                Ya, I wonder. If there was a way to just push a button as you exited the car, that would be SHWEET!!
                REMEMBER: Be safe and have fun is Rule Number 1.
                The Epic Unbuild of Clint Eastwood
                • michaelpjones
                  • Dec 2010
                  • 36
                  #128
                  has anyone figured out the "pppp"?
                  • BMWManiac
                    • Dec 2010
                    • 1091
                    #129
                    I ended up replacing the OBC with a known good one....if none of the tricks to reset it works, it may be bad.
                    • efficient
                      • Feb 2012
                      • 3312
                      #130
                      Gonna bump this up. Anyone know if the obc is supposed to stay on when the car is off? The functions dont work aswell as the light when The key is not in, it just keeps blinking like if its just giving the time. is that normal?
                      I replaced my obc, the one I replaced te screen was broken.
                      • Balleristic31
                        • Aug 2009
                        • 4198
                        #131
                        Yes that's normal
                        -NICK
                        • efficient
                          • Feb 2012
                          • 3312
                          #132
                          Thanks!
                          • Dalejandrino
                            • Feb 2012
                            • 307
                            #133
                            my OBC wont light up anymore. it used to be backlit all the time so i could see it in the dark or even during the day but now it doesn't light up anymore.
                            Does anyone know how to fix it? I know it's not broken because I can still see the numbers when I put a light up to it and the time changes and everything but I can't even see it during the day. Please help!!
                            -1987 325is coupe(SOLD)
                            -1990 325i sedan
                            • fporro
                              • 1859
                              #134
                              your answer lays in your question. keyword ... backlid
                              • Robotin
                                • Jun 2011
                                • 4471
                                #135
                                look deeper into your question, and the answer will rise within itself grasshopper.
                                1989 325i SETA stroker [delphin] R3V'd 8/31/2011
                                1989 325ix [zinnoberrot] $OLD
                                1970 2002 [Nevada]
                                Originally posted by Herr Faust Schinken
                                guy must have slid into something that doesn't look like a car vs car hit
                                Originally posted by ak-
                                Must of slid into Rob
