Before & After Bumper Tuck Pics?
tomorrow im going to drill out the bumper shocks at work once we close so the cleaning crew can take care of my mess..Comment
have not had a chance to drill mine yet. been too busy replacing the control arm bushings. next step will be these. so I guess I gotta take before photos.Comment
get the part numbers off of real oem, http://realoem.com/bmw/ Then give Blunttech a call, http://www.blunttech.com/
front bumper, http://realoem.com/bmw/showparts.do?...51&hg=51&fg=15
rear bumper, http://realoem.com/bmw/showparts.do?...53&hg=51&fg=15
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hpComment
I just used a dremel to remove mine 5 minutes ago. They get in the way of the updated valance during the swap. BTW you dont have to remove the db's to tuck them. Just lie under there and drill. I know this method works because i've done it.Comment
Is this for front and back?
So, lay under, drill, press bumper in and done?Comment
Exactly. I used a larger, more oval shaped ( and robust) composite paper plate. It catches everything a lot better. Lie under and drill front and back. I then went and found the back wall of a local wholesale store and gently bumped them in. I recommend you bring a friend to help you. You really need No speed whatever, just a little *tuck* good luck!Comment
[IMG]http://www.r3vlimited.com/board/
