Before & After Bumper Tuck Pics?
Ok so i tukced my front and back but for the front bumper i found no way of putting it back since there is no space to access the bolts. Any help??? Im sure this has been asked before but good lord this is a pain.Comment
You really don't have to. But it makes it a lot easier if you want to get in there and clean behind the shrouds and everything, or paint.
I'm of the opinion that anytime you've got major parts of the car taken apart, you should always clean up behind them.Comment
~Rogan
'85 325e w/M42 swap
'02 WRX 2.5L Hybrid w/GT32 @ 20psi - 400+awhp :: SOLD
http://www.autismspeaks.org ||| http://www.essentialpieces.org
Strategic Alpine Command
Diving Board DivisionComment
Angle grinder + cutoff blade. Make two "access" rectangles in the underside of the DB that are a little wider than the shock mount, and about 2" deep. Assuming you marked where the shocks were attached to the bumper correctly you will be able to still thread the bolts in. At most I got two in.. with a stubby ratcheting wrench. Major PITA. The majority of the time though only one bolt was doing the job, but it was never an issue.
This way you can tuck the front in 100% on an early car.. . .
ErikComment
I'm gonna be tucking mine this weekend.. Hopefully, I wont get too soaked in hydraulic fluid when I drill 'em out ;)~Rogan
'85 325e w/M42 swap
