Bumpers, bumpers, bumpers!
  • custom e30
    • Nov 2009
    • 347
    #226
    wow scab, cry becuse i wnna learn about e30's and cant find the exact anwsers im looking for....
    • E30QC
      • 214
      #227
      non db to db? ever?
      • Mike30e
        • Jan 2009
        • 410
        #228
        Has anyone ever tried this method to do a bumper tuck? This was in this DIY section, the very last entry.
        15.2.2: Tucking in large front bumpers
        (NOTE, this applies to the large 5mph silver bumpers on pre-89(?) E30s)
        for anyone who has an E30, don't know if this applies to any others, and want
        to shrink the front diving board, here's what to do. There is no need to
        drill out the bumper shocks, nor replace them with 89-91 shocks which I was
        about to do. Instead,
        >remove bumper
        >remove shocks
        >loosen lock nut at the opposite end of shock about 1.5"s
        >while holding shock body, turn the mount end clockwise and you'll magically
        see the shock length decrease. You can keep turning until it bottoms.
        >align the mount so that it will be vertical after the shock has been
        replaced and tighten the lock nut.
        > mount the shock, you will have to fiddle with the play in the shock mount
        to the car in order to achieve the correct height from side to side so that
        when the bumper is installed there is no gap along the top.
        >actual time 20mins to do. This is a good time to check the turn signal
        connections for corrosion, apply lithium grease here.
        THIS WAS SO EASY AND THE APPEARANCE IS SUCH AN IMPROVEMENT
        • JasonC
          Site Manager
          • 14451
          #229
          >remove bumper
          >remove shocks
          I don't think that there is a nut at the end of the shock....
          1992 BMW 325iC
          1978 Chevrolet Monte Carlo
          • Leaf
            • Apr 2009
            • 985
            #230
            He's to busy crying cuz my dick is to large for his puny asshole.
            • E30_pilot
              • Sep 2005
              • 1461
              #231
              Originally posted by dinanm3atl
              Anyone?
              I know the shocks will bolt on but I need to install the side supports and since I have a 1988 I assume the body already has the plastic bumper support holes for mounting said supports...
              Anyone who actually did the swap on a 88 comment? Alternatively have a friend with a 1990 325i coupe so definitely could make a template if need be.
              Im pretty sure there are holes are already drilled.If I recall correctly the holes are used to mount the bumper surrounding on the '88. Just make sure you have the plastic bumper shocks. When we did my friend's '88 car there were gaps and I had to drive home and give him my spare plastic bumper shocks and gaps are gone.
              -Frank
              1987 325is m50nv (schwarz)
              1990 325is (sterling silber)(sold)
              2001 525i
              • georgE30
                • Nov 2009
                • 172
                #232
                Originally posted by 318driver
                Ill add to this i guess about verts to clear that up.
                Any year Verts can swap plastic bumpers on there car to replace the metal bumpers. However the rear valance on coupes is part of the uni body.
                i have an 89 vert, and both front and rear plastic bumpers. However, i do not have the plastic part that goes under the rear bumper and hugs the exhaust. Is this the "unibody" you are referring to, if so, how do I obtain, and attach it to the plastic bumper I have?
                • constructor
                  • Aug 2007
                  • 977
                  #233
                  The part that is below the rear bumper of an original plastic bumpered car is not a plastic add-on. It is steel and, yes, part of the unibody. To do it right you would have to cut it off of a parts car and weld it onto the body of your car. It does not attach to the bumper.
                  • Peterkaczynski
                    • Nov 2008
                    • 2587
                    #234
                    ok question here, i have an 87 vert and i dont want to keep my stock db and im taking my kit off what would you guys suggest?
                    e24 e9 e30
                    IG: peterkaczynski
                    • NC325iC
                      • Mar 2004
                      • 6565
                      #235
                      plastic bumpers, you have shallow rear arches right?
                      • Peterkaczynski
                        • Nov 2008
                        • 2587
                        #236
                        yup but with the plastic bumpers dont i have to do heavy mods to it?
                        and thanks for the quick response
                        e24 e9 e30
                        IG: peterkaczynski
                        • NC325iC
                          • Mar 2004
                          • 6565
                          #237
                          afaik, the only mod youll have to do is something to hold the sides of the rear bumper up. you shouldnt have to cut the bumpers to shorten the sides.
                          • Peterkaczynski
                            • Nov 2008
                            • 2587
                            #238
                            i night keep my rear skirt on that i have now but all im worried about the front, so the from plastic bumpers will just come on no problem?
                            e24 e9 e30
                            IG: peterkaczynski
                            • NC325iC
                              • Mar 2004
                              • 6565
                              #239
                              front plastics fit any e30 no problem
                              • siggy
                                • Oct 2009
                                • 339
                                #240
                                fanny-lifted rear
                                DB-to-PB with a Hartge apron. Changed things up for sure. Any know of a Zender or RD rear apron source that I can try, let me know.
