Shift Lever and Short Shifters
  • Den
    • Mar 2004
    • 162
    #46
    The horizontal rod("selector shaft / rod") that attaches to the transmission needs to be bent in order to clear the harmonic balancer ring on the driveshaft of some models.
    • LikeCDoos
      • Jan 2004
      • 2522
      #47
      I just installed my Z4 2.5 lever and love it alot. I kept my harmonic balancer on and didn't have to bend or modify anything to make it fit. Here are the pictures.
      Before:
      After:
      • Gus
        • Jan 2004
        • 285
        #48
        what is the z3 M lever like compared to the Z4 3.0? the z3 looks like it would sit higher, and therefore closer to your hand...??
        JUNGL3
        1990 "333i" Sport
        • kencopperwheat
          King of Kegstands
          • 14396
          #49
          The throw of the Z3 M lever is nearly identical to that of the Z4 3.0. The Z3 M knob will sit a bit higher, and thus the lever below the fulcrum will be a bit longer.
          Originally posted by Gruelius
          • Gus
            • Jan 2004
            • 285
            #50
            i would like a higher gear knob....are both the levers straight, or bent sideways like the e30 one?
            JUNGL3
            1990 "333i" Sport
            • ///M Powered
              • Jan 2004
              • 1109
              #51
              review:
              i installed the z4 3.0 lever into my 1984 318i yesterday ( this thread really helped thanks guys) The throw is very much shorter and notchy as hell ( driven my car 4 tiems since the install) and i love how it feels.
              problems : the plastic shift bushing i ordered did not fit because the radius was too big. Since aaron had replaced his, we used the one from his cabrio ( sanded to make it fit).
              other than that, we didn't encounter any major problems. One other thing was we had a problem getting the selector rod back on, but that's because there was a big washer we didn't see :P after it was removed it fit well
              i'll post some pictures when i have a nice camera avaiilable
                • 37827
                #52
                So if I install the Z3 ///M shifter, will that feel the shortest because it's longest on the bottom [below the ball]?
                Classic BMW Specialists
                Santa Clarita, CA
                www.BimmerHeads.com
                • EtaSport
                  • 2853
                  #53
                  I cannot speak for the other levers, but I have driven both an M roadster and an e30 with the M roadster lever. Installed in the e30 it was the shortest throw shifter I have ever used. Seems like 1/2 the distance of the throws in the actual roadster. It sits a little higher than the other levers, but shifts will be ultra fast. I am expecting mine in any day now, and I will hopefully be able to comment on the feel.
                  Old and improved:
                  • BS87
                    • 1606
                    #54
                    So after reading this thread, and looking at this picture :
                    The Z3 2.8/3.0 should be almost the same throw as the Z4 3.0, but sit higher?
                    • Rob
                      • 8166
                      #55
                      yup, you got it. but keep in mind, since its taller, the knob will move more as well, but it wont be a huge difference
                      BEERTECH
                        • 37827
                        #56
                        Just talked to BMA and ordered a Z4 2.5 kit, can't wait!
                        Santa Clarita, CA
                        www.BimmerHeads.com
                        • Sean
                          • 5793
                          #57
                          Post up a review when you got it installed. ;) Enjoy!
                          - Sean Hayes
                          • nd4speedm1
                            • Dec 2004
                            • 19
                            #58
                            overall which would people say is the best kit to get? and also whats the contact info for BMA
                            • kencopperwheat
                              King of Kegstands
                              • 14396
                              #59
                              There is no 'best'. It's just what you like. Just remember that shorter doesn't equal faster.
                              BMA has a link a banner ad on this site.
                              • FrustratedMunky
                                • Apr 2004
                                • 360
                                #60
                                I don't know if this is a load of crap, but my friend tells me that he's heard that ssk's are bad for the tranny. In my opinion, I honestly don't see at all how this would be true, but can someone clarify that for me? Thanks
                                '91 E30 M42 DIAMANTSCHWARZ
