Shift Lever and Short Shifters
Yes the Z4s are straight without the bend. This causes it to sit a little bit forward compared to the normal bent levers.
Annoying at first, but you'll get used to it eventually. :D
* If you look at the picture of my shifter above, that's in N and you can see it's sitting a little forward.Comment
Just letting the world know, i got one of those ebay Ralco kits, and they are awesome. It dropped right in and made a huge difference. I recommend it to anyone.
If you like a bit notchy feel and VERY short shifting, give Ralco a try.
'89 325i - Totaled... good bye my love...
'87 327i budget stroker - SOLD!!!
'92 240sx - ca18det powered drift toy - SOLD!!!
'89 325i - coupe - NEW daily
'96 Audi A6 Quattro- Grocery getter/baby hauler
'99 Busa - weekend wheelie monsterComment
bringing it up to the top, can you use the m coupe or m z3 roadster shifter? i heard the m coupe one is alot shorter and notchier. I kinda like notchy shiftersComment
So who has modded a z3 1.9L shifter? I want to shorten the height. I have an aluminum welder.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_TwinComment
Z3M shifter here.. fit right in tho car has no balancer. not sure if i was given a support arm for the stick that was too short or what the deal was but i had to get someone to weld a peice of 1 inch length aluminum in the support arm to be able to get into reverse and 5th without hitting the trans tunnel. FWIW the support arm was ordered from BMW (dontremember part num off hand) and when i compared it to the arm that was on the gearbox previously it was about an inch or so shorter.. gives uber short shifting but it is notchy. notchyness doesnt bother me tho, hardly notice it when ur ramming it into the next gear anyway. i did also install a UUC RK2 to add a little weight to the shifter. it kept pulling off with that weeny grub screw so i put in a small bolt and tightened it... alot... lol
Currently E30-less
- EthosMotorsports.comComment
i'm encountering problems fitting my mz3 shifter with an e36 driveshaft. I'll be using the UUC Effort Reducing Kit (raised shifter cup) to help gain clearance and eliminate notchyness. The throw is absolutely perfect.Originally posted by FredKHowever, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
My year in Germany
FeedbackComment
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]Comment
ok so I bought a shifter from someone at the picnic this year ans on of the numbers is rubbed off so i cant tell if its a z3 or z4 shifter so i went to kuni and Curt sat with me for a good part of an hour tryin to find out which car it is off of and what I would need to put it in. unfortunately again we couldn't find it but I will say Kuni has all the parts for the E30 to do the short shifter swap. But when i went to put it in yesterday I couldn't get the stock shifter out on the nylon cup. I had my buddy pushing from the bottom with a screw driver and I pulled form the top and it just wouldn't budge. So any ideas?
CBAKE
86 Eta (sold)
88 325ix (sold)
87 325iComment
CBAKE
86 Eta (sold)
88 325ix (sold)
87 325iComment
My Z4 2.5 Shifter review here with pictures.....
DaveE30 Dinan Turbo
