Shift Lever and Short Shifters
  • cardnation
    • May 2012
    • 123
    #856
    Originally posted by NufnSus
    I know it's an old post, but it's also arguably one of the most informative in this thread - just a couple of Q's;
    Does this part wear significantly enough to warrant replacing (and will replacing it gain enough benefit to outweigh cost)?
    pelicanparts wants $58 for this bracket (!!) - anyone know where else I could source one from at half the price, like stated above?
    Most replace only the bushing. A forum member sells a delrin replacement.
    If you want to replace the entire bracket, these guys are awesome. http://www.thebmwpartstore.com
    • NufnSus
      • Apr 2012
      • 119
      #857
      ^thanks for the heads-up - found the member/ FS thread;
      exactly what I was looking for!!
      • iwantspeed
        • 3164
        #858
        Originally posted by Blackout
        This is fantastic Alex. Good find!
        thanks bob
        :up: :up: :up:
        Glad I was able to help
        I am currently running that bushing and its great don't hesitate to buy one.
        Project
        Parts for Sale
        Feedback
        YouTube Channel
        • iwantspeed
          • 3164
          #859
          Made a little video of the new dssr
          UUC evo 3 shift lever
          UUC 187mm DSSR
          late model centered shift knuckle
          new selector rod seal
          Garagistic front shift carrier delrin bushings
          Brent 5631 rear shift carrier delrin bushing
          New rubber shift boot body seal
          I also removed the harmonic balancer to clear the dssr.
          click the picture for the video
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • pogokat
            • 297
            #860
            just installed a shifter off an e46 330 into a 318is
            twas incredibly easy---and achieved exactly what i wanted---A shorter throw without any difference at all. The shifter itself sits at center in 3rd gear, so it's actually back a little from the stock shifter, but that's actually a very comfortable place...there is no stretching to shift at all.
            since its an m42, there was no need to bend the shift rod...just pull out the old cup and shifter, drop in the new one.
            I'd highly recommend this to anyone who doesn't want the tiny shifter look, or doesn't want to pay $100 or more for a shifter, since I was able to buy this off ebay for $44 shipped
            • iwantspeed
              • 3164
              #861
              I made a diy article on the short shifter setup.
              E30 dssr installation process In the shifter area its a great opportunity to replace several items, its a perfect example of while your in there. Parts DSSR (found here) Shift knuckle bushing shift knuckle(centered knuckle to be compatible with the dssr) New shift lever (Z3 1.9 model, great feel for a budget price.) ne
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • JRYE30
                • Sep 2011
                • 465
                #862
                Originally posted by dandan1
                Are the Z3 1.9 SSK part #s still the same as before or has it changed?
                1x . . . 25 11 1 434 148 - Z3Shift lever - $43.81
                4x . . . 25 11 1 220 439 - Spacer Rings (two extra)
                1x . . . 25 11 1 220 832 - Rubber Bearing sleeve
                2x . . . 25 11 1 220 379 - Circlips $0.50 (one extra)
                1x . . . 25 11 1 220 600 - Nylon Shift Bushing - $4.00
                Thread bump...this question was asked and nobody answered. I'm wondering the same thing.
                I would like to get a z3 1.9 shifter and replace all the major wear parts...are these all of them?
                Thanks
                1987 325 | @e30_hunter |
                • tason423
                  • Dec 2012
                  • 8
                  #863
                  so great sharing ,thank you ...
                  • JinormusJ
                    • 6887
                    #864
                    Thanks
                    Yes, that's all of the ones you need; BMA has this kit, but it's upwards to $120 shipped. Not sure if they separate it
                    • tason423
                      • Dec 2012
                      • 8
                      #865
                      sharing E24 Shift Knob with M emblem lights DIY
                      • 325ix
                        • Aug 2009
                        • 7783
                        #866
                        The PO of my car installed a z3 1.9 shifter. I love the feel of the shifts but, when I put it into reverse it pushes the center console over to the left about an inch. It is rubbing through the leather on my shift boot. Any ideas on what it could be?
                        • Butler
                          • Nov 2009
                          • 1613
                          #867
                          Installed backwards? ^
                          -Nick
                          Originally posted by 87e30
                          First of all: calm the fuck down; second of all; cool story bro.
                          • burlmays9
                            • 227
                            #868
                            I'm using an Active Autowerke E36 short throw.
                            Not sure what lever to compare it to as I've only had a eBay short throw lever before this one but this lever is much better for sure.
                            • raudonis
                              • Jan 2013
                              • 184
                              #869
                              X5 e53 facelift lever 25117543191
                              X5 e53 facelift lever 25117543191 (requires no washers by the bushing).
                              Photo not mine, just my measurements.
                              My transaction feedback on r3vlimited :):Clickety click
                              • Solarian
                                • Oct 2012
                                • 121
                                #870
                                Does this one require bending to fit?
