Shift Lever and Short Shifters
  • raudonis
    • Jan 2013
    • 184
    #871
    X5 lever
    Originally posted by Solarian
    Does this one require bending to fit?
    This lever was mentioned in this thread a dozen times.
    It needs to be made almost completely straight.
    Will need balancer removed from the driveshaft guibo (if there is one).
    Will need a longer leather cover for the interior as well.
    Different part # for this lever (some are discontinued):
    #___________Since___Till
    25117540036_2003.09_2005.03_(wide bushing)
    25117543190_1999.08_2003.09_(regular bushing)
    25117543191_2005.03_2006.09_(wide bushing)
    25111434624_1999.08_2003.09_(regular bushing)
    25117525645_2003.09_2004.10_(wide bushing)
    In my 1983 e30 with sheet steel console 25117543191 lever brought the knob ~2cm higher (compared to stock).
    Also did NOT require to cut the existing parts to fit like here: http://www.unofficialbmw.com/e30/dri...new_shift2.jpg
    My transaction feedback on r3vlimited :):Clickety click
    • Wanganstyle
      • 2828
      #872
      X5 lever installed as is; not manipulated or bent to be straight.
      The OEM BMW bend Works quite well in a race car;
      Sent from my GT-N7100 using Tapatalk 2
      • raudonis
        • Jan 2013
        • 184
        #873
        This guy installed X5 lever as is in e30 with full interior (pics inside):
        • GunMetalGrey
          • Dec 2010
          • 1499
          #874
          Put an e36 M3 shifter into a friends m50 swapped e30 with a g260, miles better than the ebay one that was in there.
          The throw is not super short, and not long. It is awesome and is not notchy.
          It's fun just having random parts laying around to try!
          • Aviator
            • 616
            #875
            I hate to ask this as it may have been covered 22 times, just don't feel like reading 59 pages at the moment. Swapping an M50 with a ZF 320 into my 84 eta. What shifter has worked well with this combo? Thanks in advance.
            84 325e Burgundrot S52 M Tech 1.
            http://www.r3vlimited.com/board/showthread.php?t=250109
            • amcink
              • 788
              #876
              Similar question, been lazy-just don't feel like reading 59 pages at the moment. Swapping an M50 with a G250 into my 87 325i. What shifter has worked well with this combo? Thanks in advance
              • mkcman17
                • Jul 2010
                • 8240
                #877
                I've tried out a dozen levers from x5 to z4m...and the best bang for the buck is from a NV 525 e34 or e36 328 with the ZF trans. They're semi-common at the yards and make the throw feel exactly as it should have from the factory. Similar to a z3 1.9 but sits a little taller.
                I have that shifter in one of my e30s and my e46.
                I also grind off a tiny bit of the material on either side to fit a generic metal washer in lieu of the plastic bushing spacer. Works great.
                1989 LN106 Hilux / 3.0TD SFA
                1974 2002tii / stock
                2002 IS300 / 5spd LSD
                • $hane
                  • May 2011
                  • 366
                  #878
                  love my z3 2.8 lever. made new front and rear carrier bushings and my own selector rod and everything is rock solid.
                  • Coach
                    • Jul 2013
                    • 59
                    #879
                    HELP! I accidently pushed the selector PIN into the transmission.
                    This happened as I was pressing the new selector joint over it.
                    Has this happened to anyone? Please let me know how to retrieve it!
                    I have a 1984 325e (sheet metal console - I'm adding a dssr + roadster m shifter).
                    • Coach
                      • Jul 2013
                      • 59
                      #880
                      Fixed it!
                      • bpsu07
                        • Oct 2013
                        • 59
                        #881
                        What is the shortest SSK, as far as height goes? I noticed the Z3 shifters in the E30 are only about 1/2 inch "shorter" (height) than the stock one.
                        • Wanganstyle
                          • 2828
                          #882
                          AKG billet shifter
                          Or
                          Bmw X5 shifter + jaffster tall shift knob.
                          • 36brua
                            • 689
                            #883
                            check out this puppy to replace Jaffster
                            The Condor Weighted Shift Knob Weighing in at 223 grams (7.9 oz),:o
                            with Bmw X5 shifter
                            My CA legal M60 swap
                            The happening in our garage
                            • DIIRTY-30
                              • 1665
                              #884
                              hrrrmmm
                              BLUE NOSE - M62 SWAP
                              THE E30 + 1 BUILD
                              • Wanganstyle
                                • 2828
                                #885
                                with Bmw X5 shifter
                                Interesting; we could rock it with top hollow no weight; i sent the Jaffster flying in the cabin about 2 hours into my stint and finished the 3.5 hour stint with NO SHIFT KNOB. LOL
                                - as long as its tall I have no need to rock the jaffster and could battle with the condor unit if it was sponsored........
                                our car has waay too many shits for a heavy shift knob
                                Condor: want to sponsor our #40 ALMS?? We would rock it with battle footage :)
                                Log into Facebook to start sharing and connecting with your friends, family, and people you know.
                                current sponsors:
                                Edge Motorworks
                                Bimmerworld
                                WinMax Japan brakes as a full sponsor for custom pads to suit rx7 front/e30 rears
                                Red-Eye garage apparel
