DIY - All Red Taillights
  • Number dude
    • 18
    #166
    Haven't read through all of this, but the issue isn't that they can't be sprayed from the inside and turn out red, the issue is that there's no way to get to the corners (you'll notice the C shape i'm talking about if you look at them). What my old roomie did was put a light coat on the inside and a light coat on the outside and a little thicker coat on those C sections. Turned out pretty good, reduced the amber you saw with just it on the outside.
    • Uber E30
      • 1409
      #167
      Originally posted by Kristeun
      ^Just wondering is that legal in CA? the reverse and turn lights.
      Technically no, altering the lights to anything but red or clear is illegal. Altering the reverse is bad too, aside from general ascetics thats why i left mine un-tinted. Altho running euro trim is illegal too, dot requires all cars to have an amber sidemarker in the front and a red in the back. But no one seems to care about that either =]
      -Alex
      • Stephen
        Шлем ишака
        • 10774
        #168
        Originally posted by Danny
        Red is legal, smoked is questionable...
        Cops won't bug you if light output is near good as stock.
        Not sure of the ACTUAL rule though.
        Theyll stop you if you have blackout tails, but just a touch of tint and im sure you're fine.
        Dannys level of tint looks best IMO anyway
        • Kristeun
          • 396
          #169
          If I'm redoing them will acetone mess up the finish or is it safe?
          88 325is
          • thereisnoyun
            • Feb 2007
            • 2301
            #170
            posting some updates, since updates are good :)
            first time go around
            products
            - testor candy apple red
            - duplicolor clear coat 1 coat
            human error
            - didn't know how to spray paint 2.5 years ago.
            - never polished or sanded or wax.
            - rarely wash the tails when I wash my car
            result
            - faded after 2.5 years. flaking only recently
            - it definitely faded from sun exposure
            - no garage, I park outside
            second time go around
            will be using
            - metal cast red
            - nightshade vht
            - duplicolor clear 3 coats
            will also be
            - wet sanding, polishing, and all the shabang.
            One thing I did notice since I still have some left over of the testor.
            the advantage of using duplicolor is that they have the fan nozzle. It beats the hell out of the regular spray can with the splotch sprayer found on the model paint cans.
            will post pics when done.
            • Jand3rson
              • 37587
              #171
              Duplicolor's rattlecan nozzles are amazing. They deliver the best application of any spray can I've ever used.
              • deutschman
                • May 2008
                • 5958
                #172
                might be a repost but what the hell. it might help some one.
                all read tail light diy right up:
                this guy has some other cool diy stuff on his page
                • Kristeun
                  • 396
                  #173
                  From what I've seen in real life Metalcast is a much better match than Testors anyways.
                  88 325is
                  • thereisnoyun
                    • Feb 2007
                    • 2301
                    #174
                    I'll hit some pictures up later, still in the process of doing this. but the duplicolor spray nozzle is must better than when I was using the testor. The paint match I think is about the same. I dont think one matches better than the other, it depends on the person doing the spraying.
                    I hit it with some vht nightshade after the metalcast and will do two or three coats of clear after that. In general the metalcast I will say is easier to work with than the model paint. I spray too thick on one of them and I was able to easily wet sand and polish down so the two tails look the same. I dont recall the testor being as easy to work with. I remember trying to sand it down when doing the testor and having to respray because the model paint tend to flake when sanded.
                    Nightshade is difficutl to get jsut the right shade. It seems like its all or nothing with the night shade. You can barely see the difference to a little too much tinting. well thats jsut my experience.
                    • BTP325ic
                      • Apr 2009
                      • 700
                      #175
                      great write up i am gonna be doing this very soon should look good on a henna car.
                      • td325ic
                        • Feb 2006
                        • 788
                        #176
                        will be using
                        - metal cast red
                        - nightshade vht
                        I think if you're going to spend all the time to redo them then you should spend the few extra bucks and spray them with urethane clear coat. Grab a can of Spraymax 2-part urethane clear coat, comes in a special spray can. It sells for $20 at automotive paint supply stores.
                        Here's some tail lights I did last fall:
                        They are done with Duplicolor MetalCast Red. First sprayed 3 light coats on the amber, then sprayed the whole light with 2 medium coats.
                        Waited a few days for metalcast paint to cure
                        Then sprayed with SprayMax 2-part Urethane Clear Coat Aerosol
                        Let cure for a couple days then wetsanded with 1500 - 2000.
                        Used Porter Cable 7424, polished out sanding scratches with 3M Rubbing Compound and orange foam pad. Finished off with Menzerna Micro Polish and Gray foam pad.
                        YouTube Video
                        Pictures not enhanced at all, that is exactly what they look like in person
                        • BTP325ic
                          • Apr 2009
                          • 700
                          #177
                          hey td325ic those look like after market lights great work.
                          • deutschman
                            • May 2008
                            • 5958
                            #178
                            i followed the diy article i posted above and they came out great!
                            • Jand3rson
                              • 37587
                              #179
                              YouTube Video
                              Those look amazing. Very professional looking. I might just have to do another set using the Metalcast and sell mine.
                              • Asbradley21
                                • Jun 2008
                                • 1938
                                #180
                                I used Rustoleum Stained Glass paint on mine, no clear. It's meant for outdoors, so it didn't need it.
                                S54B32 swap in progress. Status: Getting There
