Replacing the E30 Heater Core and Valve
  • noE30
    • Jun 2008
    • 2260
    #61
    Is there any way to test a heater core to see if it is still good? The heater core in my car is starting to leak and the PO gave me a complete heater/ac box, I want to know if the replacement one is good still before putting in my car. Or should I just buy a new one?
    Flickr
    @michael.colby on Instagram
    "All he needed was a wheel in his hand and four on the road"
    • Das Boots
      • May 2008
      • 160
      #62
      I was told that there are two different kindss heater core. A/C or non-A/C. This with A/C? And also to replace the hear valve. Perfect time since I might have a pinhole leak in my core.:up:
      "....for the land of the free, and the home of the brave."
      Lawrence
      '89 ///M Technic II Coupe...Gone but not forgotten
      '90 M3...Garage Queen
      '91 325i Cabrio.....Son
      '92 525i...My DD
      '03 530i....S.O.'s DD...my headache
      '06 530i....Gone
      '92 Previa...My previous DD and spare
      '03 Highlander...Daughter & grandkids hauler
      BMW CCA San Diego Chapter
      #192742
      • Luke!
        • 762
        #63
        bump for a question
        I need to replace the blower motor in my buddies E30 Cab
        Is it fairly easy to get to, or do I have to remove the whole dash?
        • Ferdinand
          • 205
          #64
          The blower motor is accessed through the engine compartment. There is a hatch on the firewall, above the rear of the engine. It's easy.
          • Luke!
            • 762
            #65
            fewwwww
            thanks bro
            thank god for that!
            I did the same in my sisters Toyota, had to take apart half the car
            • CreamE30
              • Mar 2008
              • 1177
              #66
              OK R3v, here's what I'm up against. Not sure if this was just a self explanatory thing, but I have an extra obstacle in my way:
              The hell is this thing? It looks like there are three bolts holding it in, two along the transmission tunnel, and one under the steering wheel trim pieces:
              Can I take this out? Or will it end up being the backbone of my E30 and everything will fall off my car?
              <---Goodnight, sweet prince
              • quikveedb2
                • Sep 2007
                • 2258
                #67
                Originally posted by Jean
                You can remove the heater core/valve and just connect the two hoses near the firewall together to by-pass the whole thing for the time being.
                iirc, it's better to just plug the hoses rather than loop them, as it can cause the car to run hot.
                another pointer, i'm surprised nobody else has thought of this or mentioned it: you can "prime" the heater core by filling it through the pipes that come out of the firewall before you reattach the hoses, i did and it made bleeding the cooling system a 5-minute job. much easier than trying to coax all the air in the core out through the bleeder screw @ the t-stat.
                You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
                • e30shmobberr
                  • 1934
                  #68
                  wtf?? never seen that before
                  Patrick - IG:niicknac
                  RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                  • Jean
                    • 18228
                    #69
                    I don't think so. Think of it this way, people turn the heater ON and fan on MAX when bleeding the cooling system and/or if the car runs hot... not the other way around. By plugging the hoses you are limiting the coolant flow
                    • ///digitalme
                      • Dec 2009
                      • 2088
                      #70
                      i saw this at the yard...on 2 cars...they were on late model cars...and for this reason i couldnt get a heater core! but the ones i saw at the yard were welded...atleast yours are held by bolts...
                      • thesheikh
                        • Dec 2010
                        • 65
                        #71
                        +1 on this thread. very helpful
                        • T La
                          • Dec 2009
                          • 190
                          #72
                          My driver's foot well has been damp with coolant for a while now, and is greasy windshield a symptom of failed heater core? becasue i've been having that issue as well.
                          I have a 91 318is and i was wondering if my car has the metal pipes that this DIY is meant for, also, does anyone have a part # list for this replacement?
                          • quikveedb2
                            • Sep 2007
                            • 2258
                            #73
                            them be the symptoms, replace it asap! as far as i know most us cars have the metal inlet pipes.
                            • T La
                              • Dec 2009
                              • 190
                              #74
                              what are the part no.s for the pipes going into them though?
                              • T La
                                • Dec 2009
                                • 190
                                #75
                                any word on removing that strange metal piece? I have the same problem....
