DIY - ABS relay repair - Fix that ABS light
  • mkcurcio
    • Oct 2013
    • 1
    #76
    Fuse for ABS Relay
    I saw a couple of people hacking this relay. I think on the side of the relay, it says the fuse value is 7 Amps. I seem to remember seeing it somewhere. My relay has the whole internal schematic of the relay on the outside. I just soldered a piece of wire into the relay, where the fuse wire was, and then cut the wire leading into it, and installed a fuse holder with a 7.5 amp fuse. Seems a lot cleaner, than hacking up the relay cover.
    • BMWManiac
      • Dec 2010
      • 1091
      #77
      Originally posted by propr'one
      just bumping this up. I have a 90 car (iX), doesn't seem to be a relay under the driver panel, visually inspected the relatys on the ABS pump, and they look fine.
      what's the next step?
      Bumping an old thread....I have a '91 BMW 325i with my ABS light constantly on and I am having the same issue....cannot find this silver relay under my driver side knee bolster area. Did older models have the relay somewhere else?
      1997 Artic Silver M3
      CES GT4094r 651hp/615tq @ 24 psi
      • smbstyle
        • Mar 2015
        • 24
        #78
        I'm having the same issue with my newly acquired 91 318is, ABS light is on intermittently. It was on for about the first 400 miles of my trip home, then off for about 50 miles, then on again.... possibly the relay?
        • dude8383
          • Jan 2005
          • 10387
          #79
          That's most likely an ABS sensor. If its the relay it normally isn't intermittent.
          • partner103
            • May 2013
            • 305
            #80
            The original link gives me a page cannot be found. :(
            Originally Posted by mpowerful
            Ive been looking at this thread ever since it got posted and every time I do my peepee tingles a little.
            1991 Alpinweiß Sedan.... mah mistress. <-click :pimp:
            • rkhames
              • Jun 2015
              • 4
              #81
              After reading and re-reading this thread and about 15 others online, I absolutely cannot find this relay. I have dropped the ABS computer down and out of the way and there is nothing there. I cant even find anything that looks like the relay would plug into. I've checked under the hood and removed the plastic cover on the pump assembly. There are 2 relays there but, from what I understand, those serve different purposes and aren't the relay I'm looking for. I've looked through my Bentley manual. All to no avail... Yes, the car has ABS :)
              Can somebody point out where this thing may be that I haven't looked?
              Thanks in advance.
              • BMWManiac
                • Dec 2010
                • 1091
                #82
                Is your car a '91?
                • rkhames
                  • Jun 2015
                  • 4
                  #83
                  Sorry, should have posted that. It is a 1989. 325is. I am not the original owner. PO did a stereo job but, not much else. I can only wonder where this relay is. If he moved it, I should be able to at least find the wiring and lead me to it but, I can't see anything remotely helpful up in there.
                  • Stapes
                    • Feb 2015
                    • 117
                    #84
                    Great post.
                    Originally posted by danny325is
                    Hell All,
                    I did a quick write up on how to repair the ABS relay that always blows. Now you get the ABS light to go out.
                    Tell me what you think.
                    Great post Danny.
                    After owning my firts e30 (1986 325e) for six months I never thought fixing my ABS light would be straight forward. My rely's built-in fuse was burnt (original dated 9/85!!) I'm always amaized at how stock the car was maintained. Went to O'Reilly and got some 8 amp GBC fuses and replaced the wire, problem solved!
                    I found the rely clamped on top of the bracket holding the ABS.
                    • rkhames
                      • Jun 2015
                      • 4
                      #85
                      It is very weird. I can't find the relay or that wiring loom anywhere under the dash. Is there some other place it might be hidden?
                      • Seawolf
                        • Feb 2015
                        • 270
                        #86
                        Note, late model (89 on) cars don't have this relay under the dash. Later cars have an integral relay on the ABS hydraulic pump, the integral relay does not have a fusible link.
                        Just done this on my 88iX, I used single core telecom wire to replace the relay internal fusible link and spliced an insulated ATC fuse holder with 7.5amp fuse into the red wire (this is where the relay internal fuse link is connected to), a lot less work than drilling the relay case though this write up was very useful.
                        Total cost - $7.11c from AZ including a bunch of fuses.
                        • rkhames
                          • Jun 2015
                          • 4
                          #87
                          Seawolf, thanks for the info. I had gone crazy looking for it and just gave up. So, if the relay doesn't have a fusible link, then I just replace the relay?
                          • Seawolf
                            • Feb 2015
                            • 270
                            #88
                            You can get the circuit diagrams from http://www.wedophones.com/BMWManualsLead.htm
                            I pulled down the 89 is version for reference since you're not alone in fruitlessly searching for this under dash relay on late model cars.
                            Page 3450-0 (page 42) refers to early production cars, the box in the middle "Over Voltage Protection Relay", you can see the 8amp fusible link.
                            Pages 3450-2 & 3450-3 (pages 44 & 45) show the later production car circuits. The pump relay is shown on 3450-3 on the right inside the ABS Hydraulic Unit block.
                            Troubleshooting....I don't know, I don't have a late model car to look at.
                            If you can pull the relay you could feed it 12v to pin 85 and ground 86 to check that the relay is closing - if it's working you should have open circuit disconnected on pins 87 & 30 and closed circuit when you apply power.
                            Also check those ground wires (G200) coming out of the ABS ECU, followed by voltage checks on the relay socket itself.
                            • shoshottz
                              • Jun 2016
                              • 123
                              #89
                              yea this thread needs a revive.
                              shottz.
                              • driftxsequence
                                • Apr 2015
                                • 203
                                #90
                                Has anyone figured out how to repair late model ABS?
                                325IX Build Thread
                                RX7 Build Thread
