DIY - ABS relay repair - Fix that ABS light
89 E30 S52
Transaction Feedback. -
i need to check my relay out! my ABS light has been on since day one! (of me owning it)
i checked my ABS wheel rings and the sensors, TONS of metallic-type (looks like shattered magnets) on the sensors, and the wheel rings have TONS of crud on them.
i bet all the things together is causing my problem.Comment
can it still be the relay if the dash indicator only comes on after you drive 100 feet or so??? i had 3 used but working sensors, the 2 front and 1 for the rear so i swapped them out and replaced the worse looking of the rears and still i get the light.sigpicComment
I did this fix last week and am loving driving ABS light free.Comment
thats the wire inside the relay correct? but if that was blown, wouldn't the abs light be on as soon as you turned the key and not after u drive a few hundred feet?sigpicComment
I have my cluster out doing odo gears and thats when I saw that the PO had a piece of black electrical tape hiding the ABS "always on" light...very clever.
The lower panel is also off and I'll be darned if there's a relay in there to "fix" on the 89 cabrio I just bought.Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
The fuse is there to protect things. Im my case the zeener diode in the relay everyone is soldering solid, was bad. It was a direct short. So soldering it solid w/o proper diag is A BAD IDEA!!! The zeener is there to handle the reverse polarity spike of the magnetic feilds in the relays that are actually on the pump. Why they did it this way is beyond me. I soldered in the 2 clamping diodes in the pump relays and pulled the smoke/shorted zeener diode outta the relay everyone is soldering solid and everything is happy. In my opinion this is a correct fix. The way most are doin it gives no circuit protection... just my 2 centsNow with 2.7i power!!!Comment
