OIL PAN Gasket Replacement Tips
Is there any point to dropping the oil pump if it isn't needed to remove the pan eg are there components that are on a replacement schedule or recommended to clean or replace?sigpic
1988 Lachssilber E30 325i sedan.
Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
Retired - '83 Arctic Blue E28 528i powered by M30B32
wow, really? for the life of me I couldn't make that happen today. I was hoping to be able to raise the engine high enough and not having to remove the pump. but I still ended up removing it.
Leo
Originally posted by DrJosh View PostI jacked up the engine from the bellhousing and had enough room to remove the oil pan without removing the oil pump or anything else.
Originally posted by R3V9K View PostWhat about start up? I shattered my oil pan from hitting a rock at 60. I wanna make sure I don't damnage any internals when trying to start it. Tips? Tricks?
you might want to double check your fluid level after you're all done and ran it for a bitDas ist nicht nur nicht richtig, es ist nicht einmal falsch!
I was just defeated by the upper most torx bolt on the drivers side. It just won't budge and I was afraid I would have stripped it if I kept at it. I had to button up everything else all because of that one last fucking bolt! Arggg! :hitler:
Its semi deep into the transmission tunnel... how are you guys getting at it?
Thanks-NickOriginally posted by 87e30First of all: calm the fuck down; second of all; cool story bro.
hi there
this is very good site
you can find all stuffs here
please click below:
Top Ten Classified Website
Just another FYI on this tough job with pics..
I have driven this for 1500 miles now and no leaks.. I would recommend the gasket maker over the gasket..
I used the paper MTC oil pan gasket and put Hi-Temp RTV (Red) on both sides coating it, been a couple weeks now and hasn't leaked. I only use hi-temp on my car for all gaskets because it has a bigger operating window than the rest. Bigger the temp range, the more likely it will work."I wanna see da boat movie"
"I got a tree on my house"
Gasket help
Originally posted by bowtie2bimmer View PostDoing this as we speak. Car is on stands. Advice for getting the gasket in? i have the oil pan up and the pump bolted in. Just have to find the best way to get the gasket to line up...
Originally posted by mikelat View PostWhat I did was use small lengths of thread in every second hole on the pan to hold the gasket on while I was installing it and then after putting the bolts in the alternative holes pulled the thread out."I wanna see da boat movie"
