OIL PAN Gasket Replacement Tips
  • firemanory
    • Dec 2008
    • 488
    #76
    Where did you get the paper gasket? I recently tried to get one for my rebuild but all sources are out of stock with no immediate dates for restock...
    Originally posted by jayuuey
    i used hi-tack on both sides of my paper mtc gasket and I'm getting 1-2 little drops of oil coming from the flywheel cover weep hole when parked. i tried torqued the bolts to 11nm again to be sure. Could this be the rear main seal or would that dump oil when driving?
    Im thinking of trying again using hondabond instead of hi-tack.
    • jayuuey
      • 414
      #77
      Try, http://www.amazon.com/s/ref=nb_sb_no...Oil+Pan+Gasket
